02-02-2016, 08:49 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 413 | Need help SM-G531H FAP LOCK: ON Need help SM-G531H FAP LOCK: ON Need help SM-G531H FAP LOCK: ON UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531H/DS Software version: 24.2 Searching Samsung USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO Thank all |
02-02-2016, 12:24 | #2 (permalink) |
Member: 1327392 Status: Offline Thanks Meter: 413 | Fixed: > Added MTK auto select cpu model after scanned. > Added "Wipe EFS" option for SM-N900, SM-N7505L series model. > Optimized samsung qualcomm new security model "Qualcomm Direct Unlock" and "Bypass MSL" without root. > Optimized samsung "Reset FRP/EE" algorithm. > Fixed samsung SM-N7505 "Bypass MSL" bugs. Information: * Support qualcomm series new security model "Qualcomm Direct Unlock" and "Bypass MSL" without root, if you have a phone not in soft list, select any above models and try to do "Qualcomm Direct Unlock" and "Bypass MSL"; * Optimized samsung "Reset FRP/EE" algorithm, more samsung models supported "Reset FRP/EE" option. BST Dongle Released V3.29.00 - Discussion Here GsmBest Team Best Regards |
