07-12-2012, 19:07 | #5 (permalink) | |
Insane Poster Join Date: Oct 2008 Location: Việt Nam
Member: 885342 Status: Offline Sonork: congthanh211 Thanks Meter: 7 | Dear BillA Quote:
after typing * # 9090 # usb choose which ones that? thank you very much, I have installed the usb port but not search phone. again thank a lot!. I look forwards to hearing from you. Regards, | |
07-14-2012, 08:58 | #6 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | I got same phone as well. Its rooted, \With UART cable it says " Code: Reading Phone Info... OK IMEI: 000000000000000 Reading Security... Error Done with Samsung Tool ver 12.6 Code: Searching Samsung USB Modem... Detected (COM212) Model: SAMSUNG-SGH-I747 IMEI: I747UCLEM Done with Samsung Tool ver 12.6 LITTLE MASTER |
07-14-2012, 12:00 | #7 (permalink) |
Freak Poster Join Date: May 2004 Location: UK
Member: 65097 Status: Offline Sonork: 100.111703 Thanks Meter: 7 | i747m confirm unlock with z3x 12.6 this is what i did: Code: 1. Connect phoen to PC powered via USB and enter MTP mode (Media Transfer) 2. Copy 'SuperUser.zip' to the root of Internal Storage 3. Power off phone and go into Download Mode (Volume Down + Home + Power -- Then press Volume Up to continue) 4. Open Odin 1.85+ 5. Add 'RecoveryGalaxyS3USCanada.tar' into PDA and flash 6. As soon as flash finishes - remove battery 7. Reinsert battery and enter recovery mode (Volume Up + Home + Power -- Only hold power for around 3 seconds) 8. Once in recovery, select 'install zip from sdcard' then 'choose zip from internal sdcard' 9. Next select 'SuperUser.zip' and confirm 10. Once you get 'Install from sdcard complete' go back and reboot and root should be complete. 11. once restarted - do a full reset (*2767*3855#) 12. *#7284# - select modem 13. *#9090# - select USB and reboot phone 14. Make sure device is in USB Debugging mode and connect with C3300k cable directly to z3x. 15. open Samsung Tool 12.6 and select T989 as model and select COM for box and press unlock. and this is my unlock log: Code: -------------------------- 14.7.2012_10-31-9 -------------------------- Count supported models - 315 Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: ***********2467 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.6 |
The Following User Says Thank You to _mo_ For This Useful Post: |
07-14-2012, 14:09 | #8 (permalink) | |
Junior Member Join Date: Jun 2012
Member: 1773961 Status: Offline Thanks Meter: 0 | Quote:
I feel what austin has said is correct, rooting is not necessary. Since the moment you perform a factory reset, using the above command root is lost. You were still able to unlock your phone, this implies that the root is not required. I welcome to be corrected. | |
07-15-2012, 01:38 | #10 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | unlock done UNLOCK DONE. ROOTING NOT NEEDED FOT THIS PHONE . just switch phone to PDA ( *#7284# ) Select T989 model. Connect phone with UART , and click unlock . Code: Count supported models - 315 Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: 353091050576471 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.6 LITTLE MASTER |
The Following User Says Thank You to Little_Master For This Useful Post: |
07-16-2012, 14:09 | #11 (permalink) | |
Member: 1205146 Status: Offline Thanks Meter: 879 | My phone wasn't unlocked. I didn't tested it before manually. Customer came back , coz it was still locked. He didn't gave me a single minute again to re unlock it. And took his phone. So please paste here test report if someone really has successfully unlocked it . LITTLE MASTER Quote:
10-02-2012, 21:38 | #12 (permalink) |
Major Poster Join Date: Jul 2006
Member: 312383 Status: Offline Thanks Meter: 6 | samsung galaxy s3 att unlock This is how i get my galaxy s3 unlock using z3x box ,software v12.7 Lauch samsung tool and select model T989 and z3x serial port,select what ever port that your pc set to for the z3x box, on the phone first do a full reset by dial *#2767*3855# ,when the phone complete reboot dial *#7284# select modem and then press qualcomm USB settings and selec tDM+MODEM+ADB and plug in your phone uart cable connect directly to the z3x box and hit unlock after finish restart your phone and that how i unlock my att samsung galaxy i747 att. Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: ************0374 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.7 |
11-12-2012, 12:35 | #13 (permalink) |
No Life Poster Join Date: Sep 2010 Location: PNG Papua New Guinea
Member: 1395476 Status: Offline Sonork: Men7896 Thanks Meter: 52 | Reading phone info... Build: M8960A-AAAANAZM-1.0.443012 Reading phone info... Build: M8960A-AAAANAZM-1.0.443012 Reading security... OK Calculating... OK Reading phone info... Build: M8960A-AAAANAZM-1.0.443012 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done hihi.. I tried unlock i747..by both usb and uart cable. It shows unlock done but phone remain lock! can anyone pls help? Thanks in advance. BR |
12-24-2012, 13:54 | #14 (permalink) |
Freak Poster Join Date: May 2011 Location: ettumanoor
Member: 1587303 Status: Offline Thanks Meter: 42 | i 747 unlock done z3x elected model: I747M Selected port: COM496 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.442802 Done with Samsung Tool v.13.7 Selected model: I747M Selected port: COM496 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.442802 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.13.7 Done with Samsung Tool v.13.7 |
01-02-2013, 15:04 | #15 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: babeloued Age: 55
Member: 18688 Status: Offline Thanks Meter: 69 | Quote:
gooooooooooooooooooood job bro | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
