03-25-2016, 14:54 | #1 (permalink) |
Major Poster Join Date: Jul 2010 Location: ALGERIA
Member: 1353022 Status: Offline Thanks Meter: 6 | j700h/ds FRP PROBLEM UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Reset FRP Selected model: SM-J700H/DS Software version: 23.3 Searching Samsung USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... OK Searching partition... OK Erasing FRP... OK Reset FRP done Done with Samsung Tool PRO v.23.3 but after all google account not removed |
03-25-2016, 15:03 | #2 (permalink) |
Member: 1353022 Status: Offline Thanks Meter: 6 | yet an other log from lateset update from Samsung Tool PRO v.24.9 UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700H/DS Software version: 24.9 Searching Samsung USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.24.9 |
