02-02-2018, 14:40 | #17 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | Okay if baseband is unknow after downgrade flash this modem After flash with the firmware I mentioned above, hard reset the phone and baseband will be unknown, no worries after that flash this modem using odin in "CP" tab https://www.4shared.com/file/M7PFWI98ca/modem.html now the baseband will be fixed, then root via twrp and unlock. |
02-03-2018, 11:13 | #20 (permalink) | |
Member: 2583091 Status: Offline Thanks Meter: 413 | Doesn't matter whether you flash using z3x or odin Quote:
It is just the same algorithm that z3x and odin have for flashing .I was just showing directions don't be stubborn. | |
The Following User Says Thank You to Feiselski For This Useful Post: |
02-14-2018, 13:43 | #22 (permalink) | |
Crazy Poster Join Date: Jan 2008
Member: 670300 Status: Offline Thanks Meter: 6 | Quote:
I remember that I was using NSPRO before and it was much better at that time. No need to root to flash a firmware or unlock. Just my rant guys! | |
02-14-2018, 13:49 | #24 (permalink) |
Member: 2583091 Status: Offline Thanks Meter: 413 | Here is the firmware I used and it's available onn z3x server J700TUVU2APK6_J700TTMB2APK6 and remeber after downgrade hard reset phone then baseband will say unknown then flash this modem in "CP" tab on odin Baseband fix Modem= https://www.4shared.com/file/M7PFWI98ca/modem.html then use twrp and supersu for root and unlock |
03-24-2018, 09:33 | #26 (permalink) |
Member: 2583091 Status: Offline Thanks Meter: 413 | Guys flash this file for safe downgrade without baseband unknown J700TUVU3AQC3_J700TTMB3AQC3_TMB.zip no baseband unknown after downgrade just root and unlock |
04-13-2018, 17:22 | #27 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: Cuba
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks Meter: 27 | Clarifying Quote:
The IMEI is lost not because of anything the box did, but because you are downgrading the modem and the security has been updated. Binary 3 has new security, so, you downgrade the firmware and you loose IMEI. That is why after going back to the updated firmware you recover IMEI a other funcionalities. | |
