11-28-2017, 15:02 | #1 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | J700T 7.1.1 downgraded and unlocked using z3x. J700TUVU2APK6_J700TTMB2APK6 then root using twrp and unlock! Rooting while you are on android 7.1.1 isn't a solution because the adb will be disabled and you can't unlock so downgrade to marshmallow and unlock. If you can't find the file comment and I'll upload it. |
The Following 4 Users Say Thank You to Feiselski For This Useful Post: |
01-03-2018, 22:01 | #6 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: GV, Brazil
Member: 1064466 Status: Offline Thanks Meter: 34 | Quote:
01-04-2018, 08:34 | #7 (permalink) | |
Member: 2583091 Status: Offline Thanks Meter: 413 | What firmware did you use to downgrade? Quote:
If you used a different firmware then flash the 7.1.1 firmware which will bring your imei and baseband back then downgrade using the 6.0.1 firmware with the exact build number I posted above for higher success then root and unlock. Post result. | |
01-04-2018, 11:48 | #8 (permalink) |
Member: 1064466 Status: Offline Thanks Meter: 34 | I Flashed 7.1.1 and restore imei, tru to dowgrade again, same, baseband unknown and no imei, i was thinking was i used PK6 from metro pcs, but try with PK6 t nobile , still the same. |
01-04-2018, 13:54 | #9 (permalink) |
Member: 1064466 Status: Offline Thanks Meter: 34 | Ok i did diferent way and work, i root on nougat and downgraded only moden to QF1 and everthing is fine. |
The Following User Says Thank You to tipitiboss For This Useful Post: |
01-09-2018, 15:10 | #11 (permalink) |
Member: 2583091 Status: Offline Thanks Meter: 413 | Bro it's available on z3x server |
The Following User Says Thank You to Feiselski For This Useful Post: |
01-09-2018, 16:30 | #12 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | why not just downgrade to J700TUVU3AQC3 it is rev 3 and 6.0.1 There is always somebody that needs to make it so hard. |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
01-20-2018, 18:31 | #14 (permalink) | |
Crazy Poster Join Date: Jan 2008
Member: 670300 Status: Offline Thanks Meter: 6 | Quote:
So, I have the phone with no IMEI. What I am going to do it go back to "j700tuvu3bqk3". The after that I will downgrade to "J700TUVU3AQC3_TMB3AQC3" and lets see if it works. Another thing is that this folder/zip "J700TUVU3AQC3_TMB3AQC3" has different files eg starting with ap, bl, cp.csc. Which one do I flash and what are these different files. Its the same folder thats on z3x server. | |
01-20-2018, 19:01 | #15 (permalink) |
Member: 670300 Status: Offline Thanks Meter: 6 | I downgraded to "J700TUVU3AQC3_TMB3AQC3" and now its asking for password. Does anyone know what to do? Its just getting PITA now. I finally want to repair the IMEI. |
The Following User Says Thank You to hapishyguy For This Useful Post: |
