08-11-2016, 22:07 | #63 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2431464 Status: Offline Thanks Meter: 0 | Previous hint: enable usb debug in STOCK FW, use the factory fw and your mind to get I have used my mind and a lot of hours lol i can not enable usb debugging in Stock FW, any other hint would be greatly appreciated. |
08-15-2016, 01:26 | #65 (permalink) |
Junior Member Join Date: Jan 2015 Location: Hartford,CT
Member: 2327311 Status: Offline Thanks Meter: 5 | hey y3kt, can you please share how exactly you did it, I've been trying the adb command since oem unlock is not there. But after I enter it nothing happens and frp on still shows in download mode. Call me lazy all you (not you y3kt, speaking in general) want but not everyone is as smart as some of you guys or have enough experience as you might have. |
08-15-2016, 03:12 | #66 (permalink) |
Member: 2327311 Status: Offline Thanks Meter: 5 | ok finally found a solution 1. Flash FACTORY_BINARY_J700T_PF2 wtih Odin 2. Flash ENG_SBOOT_J700T_1_PF2.tar 3. Flash STOCK_ROM_J700T_PD2 or any stock firmware 3. Extract boot.img from FACTORY_BINARY_J700T_PF2 4. Use 7zip to convert it into boot.img.tar then flash with odin After phone rebooted has adb enabled and just ran these 3 commands in minimal adb and fastboot (to me works better than normal cmd your choice) 1- devices 2- shell netcfg 3- shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 Pretty simple with the right files, I don't really know how or where to upload them, trust me not going thru 3 hours of search history to find links. Google the files same as I typed them in steps and should come up first. I don't know if there's is a easier way, all it took me was about 10 mins, not counting all it took reading, trials, and finding the files. Only tested this in J700T dont know if would work on T1 or F. Will try to put the files somewhere for you guys stuck can download. Last edited by fullr3; 08-15-2016 at 03:14. Reason: forgot steps |
The Following 5 Users Say Thank You to fullr3 For This Useful Post: |
08-16-2016, 02:37 | #67 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 996077 Status: Offline Thanks Meter: 19 | Quote:
08-16-2016, 03:49 | #69 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Frp Quote:
08-17-2016, 19:48 | #71 (permalink) | |
Insane Poster Join Date: Dec 2013
Member: 2077877 Status: Offline Thanks Meter: 1 | Quote:
08-17-2016, 20:18 | #72 (permalink) |
Member: 996077 Status: Offline Thanks Meter: 19 | ok in my experience the ENG sboot wont stick on some phones. you have to keep flashing it and flashing it until it finally sticks lol just a heads up. as soon as you have ADB just run the command and it bypasses the setup enable oem unlocking and hard reset and VOILA! |
The Following User Says Thank You to BootyHunter57 For This Useful Post: |
08-17-2016, 21:13 | #73 (permalink) | |
08-17-2016, 21:47 | #74 (permalink) |
Member: 2077877 Status: Offline Thanks Meter: 1 | shell@j7eltetmo:/ $ insert --uri content://settings/secure --bind name:s:user_se tup_complete --bind value:s:1 s/secure --bind name:s:user_setup_complete --bind value:s:1 < /system/bin/sh: insert: not found 127|shell@j7eltetmo:/ $ |
