J700T1 j700t1uvu3aqc3 impossible FRP !!! J700T1 j700t1uvu3aqc3 impossible FRP !!! hello support this version of J700T1 j700t1uvu3aqc3 .. is the last one... is impossible to make a downgrade to Any boot before... then always when Sboot eng and others be flashed the phone is in Restart Logo mode ... and i had to back to the original firmware j700t1uvu3aqc3 to revive the phone again... Any idea for FRP... remember.. any ENG boot available stuck the phone any idea support !!! |
Try like this SAMSUNG ALL MODEL AND SAMSUNG S8 S8+ ALL FRP REMOVE EASY WAY WITH FLASH METHOD STEP 1 FLASH WITH COMBINATION FILES STEP 2 FLASH WITH 4 FILES SELECT CSC AS HOME CSE FILE AFTER FLASH FRP WILL GONE THEN JUST HARD RESET YOU CAN REMOVE ALL FRP SAME METHOD READ CAREFULLY ALL Sent from my SM-G950F using Tapatalk |
Press thanks if is help Sent from my SM-G950F using Tapatalk |
I will tell you tomorrow Sent from my SM-G950F using Tapatalk |
there is not combination files for J700T1 in z3x support !!! any idea??? |
yes its possible to unlock them with engroot oh twrp |
try this file ENG_BOOT_J700T_PF2.tar i used to removed the frp in samusng J700T1 searching in Google, y try lo load the file but error for sizes |
SELECT CSC AS HOME CSE FILE what do you mean by that? csc as HOME? do you mean flash the csc ? flash AP BL CP but NOT CSC? |
Some firmware have 5 files. BL AP CP CSC AND HOME CSC. YOU hav to select in odin or z3x BL AP CP AND HOME CSC. THIS method is from hazbul Sent from my SM-G950F using Tapatalk |
Or try like this http://forum.gsmhosting.com/vbb/show...php?p=12240741 Sent from my SM-G950F using Tapatalk |
