05-30-2018, 22:48 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: on a different planet
Member: 228253 Status: Offline Thanks Meter: 22 | frp reset g930f Operation: Info Selected model: SM-G930F Software version: 32.4 Searching Samsung modem... detected COM3 Reading phone info... Model: SM-G930F AP version: G930FXXS2DRDI CSC version: G930FXEU2DRB5 CP version: G930FXXU2DRB6 Product code: XEU Phone SN: R58K16797QW IMEI: 354074099517549 Unique number: CE12171CD17A94F50C Reading IMEI... OK IMEI: 354074099517549 (SIGN: OK) Done with Samsung Tool PRO v.32.4 which is the correct combination file I need please |
The Following User Says Thank You to mickle1 For This Useful Post: |
05-30-2018, 23:30 | #2 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1062231 Status: Offline Thanks Meter: 30 | To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Done with Samsung Tool PRO v.32.4 |
The Following User Says Thank You to MONDE-GSM For This Useful Post: |
05-31-2018, 17:40 | #4 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | reset frp using ufs method require uart cable thats rj45 cable ,no drivers needed |
The Following User Says Thank You to bright hlatini For This Useful Post: |
05-31-2018, 21:04 | #6 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | 1st Disable driver signature, to do this open Command prompt nd Type/paste the following text: “bcdedit.exe /set nointegritychecks on” and reboot pc. Now switch off phone nd use “rj45 523k Uart cable” for connect phone wit BOX port... while click ON “Reset FRP UFS”,Hold VOL Down and Power till box prompt to leave Power key... now leave power key but keep holding Vol Down till FRP reset DONE..... |
The Following User Says Thank You to -Mosin- For This Useful Post: |
05-31-2018, 21:40 | #7 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 798811 Status: Offline Sonork: astrong Thanks Meter: 16 | u can use to require uart cable no need drive, if searching only uninstall drive. u can install update..... Br. |
The Following User Says Thank You to astrong For This Useful Post: |
06-01-2018, 11:14 | #8 (permalink) |
Member: 1948608 Status: Offline Thanks Meter: 1,744 | what about Z3x COM Port Driver...? does only smart card remove UFS FRP..? wher u going to connect Phone without COM Port Drver...if it is Missing..? think twice before post...! |
