10-14-2021, 01:35 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | Emergency call only now UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button, select 'Unlock via server ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock via Server DIAG May 2020 Selected model: SM-J737VPP Software version: 43.16 Checking Login and Password... OK Balance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J737VPP Android version: 9 PDA version: J737VPPVRU7BTG2 CSC version: J737VPPVZW7BTG2 Phone version: J737VPPVRU7BTG2 Product code: SM2J737VZKPVZW CSC country code: USA CSC sales code: VZW Carrier ID: VZW Phone SN: R58M1308PZH IMEI: 354805092021157 HW version: J737V.04 RF cal date: 20190118 Chip name: EXYNOS7884 Modem board: SHANNON327 Security patch: 2020-07-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Waiting ADB device... OK Searching Samsung diag port... detected COM37 Checking diag port... OK Searching Samsung modem... detected COM36 Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Unlocking... OK Unlock done Done with Samsung Tool PRO v.43.16 |
