Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Z3X-Team Products
Old 12-23-2013, 16:28   #1 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,703
Question L720 sprint 4.3 L720VPUEMK2 unlock????
how to unlock l720 but is MK2 baseband version is safe if i downgrade the baseband on L720VPUAMDC_modem and is safe for unlock anybady i have tested
Selected model: L720
Selected port: COM398 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Reading phone info...
Build: M9615A-CEFWTAZM-4.0.17122
Done with Samsung Tool v.16.7
thanxxxx
Old 12-23-2013, 16:29   #2 (permalink)
Member: 1056255
how to do it bro....... with z3x?
Old 12-23-2013, 22:30   #3 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
thanxxxx
I have tested only the MJA... but it should be possible ... No worries because you are only downgrading the Modem ... Download the correct modem and you should be fine ... also after you downgrade to MDC and unlock upgrade back to MK2 ...
The Following User Says Thank You to jusmejose For This Useful Post:
Old 12-24-2013, 07:11   #4 (permalink)
noure30's Avatar
Member: 261437
Sonork: no
Thanks Meter: 924
http://forum.gsmhosting.com/vbb/f453...x-box-1728058/
SPH-L720_MDC_Modem.tar.zip
http://www.4shared.com/zip/wEEJa1vt/...C_Modemtar.htm
The Following User Says Thank You to noure30 For This Useful Post:
Old 12-24-2013, 08:15   #5 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,703
you have try on MJA version and all ok?you have unlock?
Old 12-24-2013, 08:18   #6 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,703
Originally Posted by noure30 View Post
thank you for this, i read on forum but this is for low version i need help for new security
The Following User Says Thank You to genci titi 2002 For This Useful Post:
Old 01-03-2014, 17:53   #7 (permalink)
Member: 455304
Thanks Meter: 417
L720 sprint 4.3 L720VPUEMK2 anybody have the modem tar for this firmware ?
Old 01-03-2014, 18:37   #8 (permalink)
prince_arsalan's Avatar
Member: 618626
Sonork: 100.1592779
Thanks Meter: 61
This Solution Not Work On Mk2 Modem Tested..
Old 01-03-2014, 21:52   #9 (permalink)
Member: 455304
Thanks Meter: 417
who tell you that i just tested it on mk2 and it work
Old 01-05-2014, 02:35   #10 (permalink)
Member: 185279
Thanks Meter: 43
Unhappy
I have a L720 Version 4.3, Base Band L720VPUEMK2
Do I can unlock it ?
Is safe change modem for this version ?
Someone tested with this version ?
Thanks.
Old 01-05-2014, 03:37   #11 (permalink)
coolmfarshard's Avatar
Member: 1085379
Thanks Meter: 65
It's safe to change the modem after unlock you can return it back download patch modem from z3x support area
Sent from my SM-N900 using Tapatalk
Old 01-08-2014, 01:28   #12 (permalink)
Member: 185279
Thanks Meter: 43
Question
Thank you for your answer, but in Z3X support I find only MDC modem, when I need return it back I should do a full flash ?, no only MK2 modem ?
Old 01-08-2014, 01:42   #13 (permalink)
Member: 185279
Thanks Meter: 43
Question
Bro, I find MK2 modem only, so I need downgrade the modem to MDC, Unlock and return modem to MK2, it's ok ?
Old 01-08-2014, 09:44   #14 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,703
you have tested????????????
Old 01-08-2014, 16:33   #15 (permalink)
Member: 185279
Thanks Meter: 43
Red face
No yet, I wanna see more posts about it.
Im not sure, I dont wanna brick my phone.
Page generated in 0.20962 seconds with 8 queries
