LG 2-3G Tool 9.32 Release. LG V20, LG X Mach LG 2-3G Tool 9.32 Release. LG V20, LG X Mach Added: - support H540D (read unlock codes, imei repair, flashing, firmware maker, read/write security zone, screen lock reset) - support H900 (direct unlock) - support H915 (direct unlock, imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset) - support H918 (imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset) - support H918TN (imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset) - support H990TR (direct unlock, imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset) - support K600 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, screen lock reset, FRP reset) - support K600HK (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, screen lock reset, FRP reset) - support K600Y (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, screen lock reset, FRP reset) * Some bug fix Special for some users added options: Write user data and misc. If you check this checkbox and write firmware software not skip user data and misc partition. Multi-language interface - for translate use Z3X LG 2-3G Tool (Z3X LG 2-3G Tool) Mega: link |
Thanks Z3X Team ............................ |
wow really helpful gift present for ours mr blang. request to you support frp reset via download mode without adb mode. |
Please add support for sprint phones, ls675, ls676, ls450, lg x power, ls775. Add apn option and unlock. |
need unlocking support for 7.0 andriod version |
Z3x LG is an excellent tool. Congratulations We need MTK platform support! Do you have plans to add MTK? |
Please add support for lg 5x nexsus h791f |
We need this update Z3X is being behind Octoplus for this ...dd support for sprint phones, ls675, ls676, ls450, lg x power, ls775. Add apn option and unlock. |
great work team......... |
Imei repair is not working properly on h918.either I don't get a port or I fget a "battery to low,change the battery" error mr blang pls advise |
is possible read firmware of supported lg phones by z3x lg tool ???? |
When will you have a solution to unlock LS997 on android 7.0??? |
Any news for lg k7 ms330 unlock? |
UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J500FN Selected port: COM16 SAMSUNG Mobile USB Serial Port Software version: 27.7 Reading phone info... Reading IMEI... Ok IMEI: 358321079529358 Unlocking... error (0) Done with Samsung Tool PRO v.27.7 j500fn unlock problam |
Lg p880 no add flashing firmware unlock and etc..please add lg p880 to the list |
