07-27-2017, 08:39 | #32 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Hi, https://mega.nz/#!y15ATAYR!wa46wSiL8...ZVuOrJT1D6_mm0 1. Download 2. Put in LG Tool dir 3. Run and try repair IMEI post result -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
08-03-2017, 20:12 | #34 (permalink) |
Insane Poster Join Date: Dec 2016 Location: Pakistan
Member: 2665448 Status: Offline Sonork: innocentsoul008 Thanks Meter: 15 | hi sir andrew_tm is there any way to unlock lg h901. the unlock option is disable for that model should i try with different model? |
08-03-2017, 20:31 | #36 (permalink) |
Junior Member Join Date: Mar 2009
Member: 1001056 Status: Offline Thanks Meter: 5 | Select lg h850 to unlock lg m151 , but after unlock , no signal , emergency call only 8/2/2017 12:11:19 AM: LG 2-3G Tool v9.38 8/2/2017 12:11:19 AM: supported models: 1513 8/2/2017 12:11:19 AM: 8/2/2017 12:13:08 AM: Mode: Normal 8/2/2017 12:13:08 AM: Model: LGM151AT 8/2/2017 12:13:08 AM: Build version: Jan 15 201719:35:19Dec 13 201623:00:00LGM151AT 8/2/2017 12:13:08 AM: SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1 8/2/2017 12:13:08 AM: IMEI: 35457608032902-3 8/2/2017 12:13:08 AM: BlueTooth Address: 00:00:00:00:00:00 8/2/2017 12:13:08 AM: Phone Code: 8/2/2017 12:13:08 AM: Elapsed: 1 secs. --> (v9.38) 8/2/2017 12:13:08 AM: 8/2/2017 12:13:08 AM: Checking phone at 8/2/2017 12:13:08 AM: COM9 8/2/2017 12:13:09 AM: Detected ID: 8/2/2017 12:13:09 AM: 0000100C (MSM8909) 8/2/2017 12:13:09 AM: SW Version: 8/2/2017 12:13:09 AM: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1 8/2/2017 12:13:09 AM: Reading ESN... 8/2/2017 12:13:09 AM: OK 8/2/2017 12:13:09 AM: Read SPC... 8/2/2017 12:13:09 AM: Unlock SPC... 8/2/2017 12:13:09 AM: OK 8/2/2017 12:13:09 AM: Backuping RFNV... 8/2/2017 12:13:21 AM: OK 8/2/2017 12:13:21 AM: Backuping Feature Mask... 8/2/2017 12:13:21 AM: OK 8/2/2017 12:13:21 AM: Backuping NV Item... 8/2/2017 12:14:05 AM: OK 8/2/2017 12:14:05 AM: Backuping NV Item SIM1... 8/2/2017 12:14:48 AM: OK 8/2/2017 12:14:48 AM: Backuping NV Item SIM2... 8/2/2017 12:15:29 AM: OK 8/2/2017 12:15:29 AM: Backuping Provisioning Item Files... 8/2/2017 12:15:41 AM: OK 8/2/2017 12:15:41 AM: Phone mode is 8/2/2017 12:15:41 AM: NORMAL 8/2/2017 12:15:41 AM: Switch to DOWNLOAD mode 8/2/2017 12:16:17 AM: Phone detected! 8/2/2017 12:16:17 AM: Read security zone... 8/2/2017 12:16:18 AM: Model name: LG-M151 8/2/2017 12:16:18 AM: Software verion: M15110a 8/2/2017 12:16:18 AM: Android verion: 6.0.1 8/2/2017 12:16:18 AM: Target operator: GLOBAL 8/2/2017 12:16:18 AM: Target country: CA 8/2/2017 12:16:18 AM: IMEI: 354576080329023 8/2/2017 12:16:19 AM: Save part1... 8/2/2017 12:16:19 AM: done 8/2/2017 12:16:20 AM: Save part2... 8/2/2017 12:16:20 AM: done 8/2/2017 12:16:20 AM: Save part3... 8/2/2017 12:16:20 AM: done 8/2/2017 12:16:21 AM: Sec zone saved: ..\Backup\H850_354576080329023_02082017_001619.lgs b1 8/2/2017 12:16:21 AM: Write security zone... 8/2/2017 12:16:21 AM: Erase part1... 8/2/2017 12:16:21 AM: done 8/2/2017 12:16:21 AM: Erase part2... 8/2/2017 12:16:21 AM: done 8/2/2017 12:16:21 AM: Erase part3... 8/2/2017 12:16:21 AM: done 8/2/2017 12:16:21 AM: Reboot... 8/2/2017 12:17:21 AM: Phone detected! 8/2/2017 12:17:21 AM: Reading QCN file... 8/2/2017 12:17:21 AM: OK 8/2/2017 12:17:21 AM: Port open fail COM9 8/2/2017 12:17:21 AM: Elapsed: 253 secs. --> (v9.38) 8/2/2017 12:17:21 AM: 8/2/2017 12:20:22 AM: Port already opened! 8/2/2017 12:20:22 AM: Elapsed: 0 secs. --> (v9.38) 8/2/2017 12:20:22 AM: 8/2/2017 12:20:31 AM: Unable to get comport information , check system 8/2/2017 12:20:33 AM: Unable to get comport information , check system 8/2/2017 12:20:49 AM: Unable to get comport information , check system 8/2/2017 12:20:54 AM: LG 2-3G Tool v9.38 8/2/2017 12:20:54 AM: supported models: 1513 8/2/2017 12:20:54 AM: 8/2/2017 12:21:34 AM: Select ComPort or use Search Phone button! 8/2/2017 12:21:34 AM: Elapsed: 0 secs. --> (v9.38) 8/2/2017 12:21:34 AM: 8/2/2017 12:21:39 AM: Unable to get comport information , check system i double check the phone usb connection , i forget to change the usb connection charging only to file transfer , it interrupt unlock , so , i set it to file transfer and unlock it again 8/2/2017 12:22:26 AM: LG 2-3G Tool v9.38 8/2/2017 12:22:26 AM: supported models: 1513 8/2/2017 12:22:26 AM: 8/2/2017 12:22:44 AM: Mode: Normal 8/2/2017 12:22:44 AM: Model: LGM151AT 8/2/2017 12:22:44 AM: Build version: Jan 15 201719:35:19Dec 13 201623:00:00LGM151AT 8/2/2017 12:22:44 AM: SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1 8/2/2017 12:22:45 AM: IMEI: 00000000000000-0 8/2/2017 12:22:45 AM: BlueTooth Address: 00:00:00:00:00:00 8/2/2017 12:22:45 AM: Phone Code: default 8/2/2017 12:22:45 AM: Elapsed: 1 secs. --> (v9.38) 8/2/2017 12:22:45 AM: 8/2/2017 12:22:45 AM: Checking phone at 8/2/2017 12:22:45 AM: COM9 8/2/2017 12:22:45 AM: Detected ID: 8/2/2017 12:22:45 AM: 0000100C (MSM8909) 8/2/2017 12:22:45 AM: SW Version: 8/2/2017 12:22:45 AM: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1 8/2/2017 12:22:45 AM: Reading ESN... 8/2/2017 12:22:45 AM: OK 8/2/2017 12:22:45 AM: Read SPC... 8/2/2017 12:22:45 AM: Unlock SPC... 8/2/2017 12:22:45 AM: OK 8/2/2017 12:22:45 AM: Backuping RFNV... 8/2/2017 12:22:59 AM: OK 8/2/2017 12:22:59 AM: Backuping Feature Mask... 8/2/2017 12:22:59 AM: OK 8/2/2017 12:22:59 AM: Backuping NV Item... 8/2/2017 12:23:42 AM: OK 8/2/2017 12:23:42 AM: Backuping NV Item SIM1... 8/2/2017 12:24:25 AM: OK 8/2/2017 12:24:25 AM: Backuping NV Item SIM2... 8/2/2017 12:25:08 AM: OK 8/2/2017 12:25:08 AM: Backuping Provisioning Item Files... 8/2/2017 12:25:22 AM: OK 8/2/2017 12:25:22 AM: Phone mode is 8/2/2017 12:25:22 AM: NORMAL 8/2/2017 12:25:22 AM: Switch to DOWNLOAD mode 8/2/2017 12:26:03 AM: Phone detected! 8/2/2017 12:26:03 AM: Read security zone... 8/2/2017 12:26:04 AM: Model name: LG-M151 8/2/2017 12:26:04 AM: Software verion: M15110a 8/2/2017 12:26:04 AM: Android verion: 6.0.1 8/2/2017 12:26:04 AM: Target operator: GLOBAL 8/2/2017 12:26:04 AM: Target country: CA 8/2/2017 12:26:04 AM: IMEI: 000000000000000 8/2/2017 12:26:05 AM: Save part1... 8/2/2017 12:26:05 AM: done 8/2/2017 12:26:06 AM: Save part2... 8/2/2017 12:26:06 AM: done 8/2/2017 12:26:06 AM: Save part3... 8/2/2017 12:26:06 AM: done 8/2/2017 12:26:07 AM: Sec zone saved: ..\Backup\H850_000000000000000_02082017_002605.lgs b1 8/2/2017 12:26:07 AM: Write security zone... 8/2/2017 12:26:07 AM: Erase part1... 8/2/2017 12:26:07 AM: done 8/2/2017 12:26:07 AM: Erase part2... 8/2/2017 12:26:07 AM: done 8/2/2017 12:26:07 AM: Erase part3... 8/2/2017 12:26:07 AM: done 8/2/2017 12:26:07 AM: Reboot... 8/2/2017 12:27:08 AM: Phone detected! 8/2/2017 12:27:08 AM: Reading QCN file... 8/2/2017 12:27:08 AM: OK 8/2/2017 12:27:08 AM: Checking phone at 8/2/2017 12:27:08 AM: COM9 8/2/2017 12:27:09 AM: Detected ID: 8/2/2017 12:27:09 AM: 0000100C (MSM8909) 8/2/2017 12:27:09 AM: SW Version: 8/2/2017 12:27:09 AM: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1 8/2/2017 12:27:09 AM: Unlock SPC... 8/2/2017 12:27:09 AM: OK 8/2/2017 12:27:09 AM: Checking paths... 8/2/2017 12:27:09 AM: OK 8/2/2017 12:27:09 AM: Restoring EFS Backup... 8/2/2017 12:27:22 AM: OK 8/2/2017 12:27:22 AM: Restoring NV Items... 8/2/2017 12:27:33 AM: OK 8/2/2017 12:27:33 AM: Restoring NV Item SIM1... 8/2/2017 12:27:33 AM: OK 8/2/2017 12:27:33 AM: Restoring NV Item SIM2... 8/2/2017 12:27:33 AM: OK 8/2/2017 12:27:33 AM: Restoring Provisioning Item Files... 8/2/2017 12:27:37 AM: OK 8/2/2017 12:27:37 AM: Unlock done! 8/2/2017 12:27:37 AM: Elapsed: 292 secs. --> (v9.38) 8/2/2017 12:27:37 AM: 8/2/2017 12:28:01 AM: Repair IMEI... 8/2/2017 12:29:03 AM: Search LG Modem port... 8/2/2017 12:29:03 AM: Detected LG Modem port at COM8 8/2/2017 12:29:03 AM: Repair done! 8/2/2017 12:29:03 AM: Elapsed: 61 secs. --> (v9.38) 8/2/2017 12:29:03 AM: this time is unlock and i repair the imei , unfortunately , it did not pick up any signal , EMERGENCY CALLS ONLY what can i do ????? HOW CAN I GET SIGNAL ????????????? i check my back up folder , i see there is 2 files there 1. H850_000000000000000_02082017_002605.lgsb1 2. H850_000000000000000_MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1_02082017_002245.qcn WHAT I CAN I DO WITH THESE 2 FILES ? |
08-04-2017, 05:04 | #37 (permalink) |
Junior Member Join Date: May 2017
Member: 2712875 Status: Offline Thanks Meter: 0 | LG 2-3G Tool v9.38 supported models: 1513 Port already opened! Elapsed: 0 secs. --> (v9.38) Mode: Emergency Model: K535 Read info... Model name: LG-K535 Software verion: K53520b Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 359383070262578 Elapsed: 4 secs. --> (v9.38) Mode: Emergency Model: K535 Read info... Model name: LG-K535 Software verion: K53520b Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 359383070262578 Elapsed: 4 secs. --> (v9.38) Phone mode is DOWNLOAD Start FRP remove... Model name: LG-K535 Software verion: K53520b Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 359383070262578 Init EXT4 ... Save EXT4... FRP Reset Done. Elapsed: 82 secs. --> (v9.38) Mode: Emergency Model: K535 Read info... Model name: LG-K535 Software verion: K53520b Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 359383070262578 Elapsed: 5 secs. --> (v9.38) Phone mode is DOWNLOAD Start FRP remove... Model name: LG-K535 Software verion: K53520b Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 359383070262578 Init EXT4 ... Restore data detected! Save EXT4... FRP Restore Done! Elapsed: 41 secs. --> (v9.38) but phone still locked frp |
08-04-2017, 07:47 | #38 (permalink) |
Member: 2665448 Status: Offline Sonork: innocentsoul008 Thanks Meter: 15 | sir will you help me i have phone in hand lg h901 want to unlock it it is locked by T-mobile Last edited by innocentsoul008; 08-04-2017 at 07:54. |
