Old 11-14-2017, 16:47   #46 (permalink)
Member: 2720836
Thanks Meter: 10
Originally Posted by andrew_tm View Post
select LS676 and unlock. post result.
Thanks unlock done OK!!...but what about APN ??....and will by nice to put it in the supported model list...for saving time and work.....
Old 11-14-2017, 16:51   #47 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Add in next update. Currently we haven't APN solution.
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 11-15-2017, 13:45   #48 (permalink)
Member: 2772221
Okay Thank for the response
so selecting ls992 and the click to unlock should work on the sprint v20? would that still work if the device is running the september security patch(LS997ZV9)?
Select LS992 and make unlock.
Post result here.
Old 11-15-2017, 15:04   #49 (permalink)
Member: 2636022
Thanks Meter: 13
Please add unlock for LS777 android 77.0 version V7.......
Old 11-15-2017, 20:45   #50 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Try and post result. This not brick your phone.
Old 11-16-2017, 16:37   #51 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
If I unlock ls755 will it work on other CDMA network? Please advise
The Following User Says Thank You to bhiret For This Useful Post:
Old 11-16-2017, 22:16   #52 (permalink)
Member: 2641603
windows defender for windows 10 detecting lg tool as a virus i have a offiical z3x box
Old 11-16-2017, 22:28   #53 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Disable your antivirus
Old 11-17-2017, 15:49   #54 (permalink)
Member: 2636022
Thanks Meter: 13
Please add LG MP260 MetroPCS and TP260 T-mobile- added Repair IMEI, Reset FRP, Write Firmware, Read/Write NVM, Read/Write QCN, Read/Write/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC.................. copy to octoplus.....
Old 11-18-2017, 17:26   #55 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
hi....
can you read Carrier Partition From This Phone !! I need It
Old 11-18-2017, 18:51   #56 (permalink)
HAITEKGSM's Avatar
Member: 8966
Thanks Meter: 31
hi thanks for update
but i gave one problem he say frp rest ok but always frp
i try with factory reset same result can u chekt it pls,
LG 2-3G Tool v9.43
supported models: 1543
Mode: Emergency
Model: M700A
Read info...
Laf Protocol: 01000006
Model name: LGM-X600S
Software verion: X600S10i
Android verion: 7.1.1
Target operator: SKT
Target country: KR
IMEI: 358596080262137
Elapsed: 5 secs. --> (v9.43)
The Following User Says Thank You to HAITEKGSM For This Useful Post:
Old 11-19-2017, 11:24   #57 (permalink)
Member: 2760625
Thanks Meter: 2
Wow amazing update thanks sir.
Old 11-19-2017, 17:48   #58 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
where is the support for lg v20 sprint (ls997)?
LG 2-3G Tool v9.43
Not detect phone! Please manual select port or reboot PC!
Mode: Emergency
Model: LS992
Read info...
Laf Protocol: ‎01000004
Model name: LG-LS997
Software verion: LS997ZV9
Android verion: 7.0
Target operator: SPR
Target country: US
IMEI: ‎359969072614756
Elapsed: 13 secs. --> (v9.43)
Mode: Emergency
Model: LS992
Read info...
Android verion: 7.0
Target country: US
Phone mode is DOWNLOAD
Start new sprint unlock...
Android verion: 7.0
Target country: US
Init EXT4 /system ...
Detecting sprint type ... using new write method... done
Unlocking...
Init EXT4 /carrier ... done
Unlock done!
Elapsed: 108 secs. --> (v9.43)
Old 11-19-2017, 17:58   #59 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
http://forum.gsmhosting.com/vbb/f453...emove-2288947/
We add in next update.
Old 11-21-2017, 20:58   #60 (permalink)
Member: 617539
Thanks Meter: 64
\par Start flashing.
\par Start reset FRP...
\par Laf Protocol: 01000005
\par Model name: LG-M250F
\par Software verion: M25010a
\par Android verion: 7.0
\par Target operator: GLOBAL
\par Target country: COM
\par IMEI1: 354953081981252
\par IMEI2: 350305260000001
\par Init EXT4 ...
\par Laf flash error: command error
\par Reset error.
\par Elapsed: 35 secs. --> (v9.43)
Page generated in 0.26847 seconds with 8 queries
