Old 03-22-2018, 11:26   #256 (permalink)
Member: 216844
Thanks Meter: 30
After hard reset my phone locked
https://imgur.com/a/efGXK
Old 03-22-2018, 14:02   #257 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Originally Posted by Selmir View Post
My phone not unlocked only emergency calls only
Checking Login and Password... OK
Ballance: 35 crd.
You have 35 credit(s) left. This operation takes 10 credits.Continue? Yes
Searching modem interface... found COM157
Reading data from phone... OK
IMEI: 359562068569413
Checking root rights... OK
Writing zTool... OK
SW Version: H34510d
Initialization zTool... (this can take 1-2 minutes) OK
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Unlocking done
Elapsed: 193 secs. --> (v9.47)
Your phone unlocked. Your phone with bad QCN(you or somebody wipe this phone before). Search H345 with good QCN and write QCN in your phone.
Old 03-22-2018, 18:18   #258 (permalink)
Member: 216844
Thanks Meter: 30
QCN is good fone after hard reset is locked https://imgur.com/a/efGXK
Old 03-22-2018, 18:39   #259 (permalink)
Member: 2822874
need help for root for lg ms631 lg k428 and lg tp450 please
Old 03-22-2018, 21:55   #260 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Contact to me in PM. Send team viewer id and pass.
Old 03-23-2018, 09:37   #261 (permalink)
Member: 216844
Thanks Meter: 30
Thanks to -andrew_tm- my phone unlocked and credit rfund
The Following User Says Thank You to Selmir For This Useful Post:
Old 03-23-2018, 12:23   #262 (permalink)
Member: 1636257
Thanks Meter: 27
need help how to root lg k550 7.0
Old 03-24-2018, 20:59   #263 (permalink)
Member: 1881776
Thanks Meter: 6
Originally Posted by andrew_tm View Post
Hi,
Yes you can. Root phone and try unlock.
I googled root for this phone cannot find root solution
Sent from my iPhone using Tapatalk
Old 03-26-2018, 15:26   #264 (permalink)
nelmaster_vc's Avatar
Member: 983297
Thanks Meter: 61
I tried a X210MA but have this error, any help please ? I have select ms210
LG 2-3G Tool v9.48
modelos soportados: 1555
Modo: Normal
modelo LMX210MA
Versión de la compilación: Nov 22 201717:52:41Nov 15 201707:00:00LMX210MA
version de SoftWare MPSS.JO.3.0.c8-00002-8937_GENNS_PACK-1.124564.1
IMEI: 35234209108272-7
Dirección del BlueTooth: 00:00:00:00:00:00
Código del teléfono:
Transcurrido 3 segundos --> (v9.48)
Ballance: 40 crd.
You have 40 credit(s) left. This operation takes 10 credits.Continuar? Yes
Searching modem interface... found COM10
IMEI: 352342091082727
Writing zTool... OK
SW Version: X210MA10b
Initialization zTool... (this can take 1-2 minutes) error(10 4.5)
Transcurrido 6 segundos --> (v9.48)
Old 03-26-2018, 20:36   #265 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
LG 2-3G Tool v9.48
Modo: Normal
modelo LMX210MA
Ballance: 40 crd.
Writing zTool... OK
Send team viewer id and pass to me in PM. I try help you.
Old 03-26-2018, 21:53   #266 (permalink)
Member: 983297
Thanks Meter: 61
Sorry man , my connection is thrown a proxy and team viewer not work, any way have doing by server because the client can not wait, thank by the way
If you can tips something to in the next time test, you can post
Old 03-27-2018, 11:57   #267 (permalink)
Member: 346148
Thanks Meter: 27
lg m550
hi
how to use unlock by server
ther no help file
thks
Old 03-27-2018, 16:00   #268 (permalink)
Member: 2113177
Thanks Meter: 5
Root LG V10 Tmobile
This achievement of z3x I appreciate it, rather I should suggest that you should find a way to route some of these devices that you mention in the listing as for example the LG V10 H901 of Tmobile version of android 7.0 this team nobody has been able to route it in this version and as you will understand if this root is not achieved on these computers there will simply be no sales trade of these unlocks. They should look for a way to do these equipment without having to route them.
Old 03-27-2018, 16:47   #269 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Thanks Meter: 215
Thumbs up LG H345 T-Mobile Unlock Done.
Hi,
LG H345 Unlocking takes 10 credits it's good enough.
LG 2-3G Tool v9.48
supported models: 1555
Mode: Normal
Model: EAAAANVZ
Build version:  Dec  9 201616:57:05May 11 201500:00:00EAAAANVZ
SW Version: MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1.19638.1.19833.1
IMEI: 35405*****8207-1
BlueTooth Address: 00:00:00:00:00:00
Phone Code: default
Elapsed: 2 secs. --> (v9.48)
Mode: Normal
Model: EAAAANVZ
Phone Code: default
Elapsed: 1 secs. --> (v9.48)
Ballance: 10 crd.
You have 10 credit(s) left. This operation takes 10 credits.Continue?  Yes
Searching modem interface... found COM73
IMEI: 35405*****82071
Writing zTool... OK
SW Version: H34510k
Calculating... OK
Unlocking done
Elapsed: 211 secs. --> (v9.48)
Thanks
BR.
The Following User Says Thank You to DEADBOOT For This Useful Post:
Old 03-28-2018, 17:26   #270 (permalink)
Member: 1453278
Sonork: 12345
Thanks Meter: 4
LG 2-3G Tool v9.48
Mode: Normal
Model: LGK550AT
Build version: Apr 17 201715:23:22Mar 21 201706:00:00LGK550AT
SW Version: MPSS.JO.1.2.c2.1-00028-8937_GENNS_PACK-1
IMEI: 35826907277414-3
Phone Code:
Elapsed: 3 secs. --> (v9.48)
Mode: Normal
Model: LGK550AT
Phone Code:
Mode: Normal
Model: LGK550AT
Phone Code:
Ballance: 10 crd.
Searching modem interface... found COM4
IMEI: 358269072774143
Writing zTool... OK
SW Version: K55020a
Calculating... OK
Reading data from phone... error(10 7.30100)
Elapsed: 169 secs. --> (v9.48)
Mode: Normal
Model: LGK550AT
Phone Code:
Ballance: 0 crd.
Not enough credits
20 credit is GONE BUT PHONE NOT UNLOCKED
Page generated in 0.22958 seconds with 9 queries
