@andrew_tm, i see you've added userdata reading as well as an option. Didn't take long. Good job and thanks. |
lg g5 tmobile h830 not supported |
last cople of days u regularly sending good update . |
please need solution for P713 pemanent LOCK disable services |
Read LG-F700L, F700K, F700S and make TOT files OK |
H850tr frp succes :D |
lg-d415 unlock help,does not show diag port after enable |
[QUOTE=andrew_tm;11800111]Please post log here. -- :)[/QUOTE Here brother: 5/5/2016 10:14:17 PM: LG 2-3G Tool v9.11 5/5/2016 10:14:18 PM: supported models: 1167 5/5/2016 10:14:18 PM: 5/5/2016 10:14:40 PM: Port already opened! 5/5/2016 10:14:40 PM: Elapsed: 0 secs. --> (v9.11) 5/5/2016 10:14:40 PM: 5/5/2016 10:14:56 PM: Mode: Emergency 5/5/2016 10:14:56 PM: Model: H815 5/5/2016 10:14:56 PM: Elapsed: 2 secs. --> (v9.11) 5/5/2016 10:14:56 PM: 5/5/2016 10:15:05 PM: Mode: Emergency 5/5/2016 10:15:07 PM: Model: H815 5/5/2016 10:15:07 PM: Elapsed: 3 secs. --> (v9.11) 5/5/2016 10:15:07 PM: 5/5/2016 10:15:07 PM: Phone mode is 5/5/2016 10:15:08 PM: DOWNLOAD 5/5/2016 10:15:08 PM: Start flashing. 5/5/2016 10:15:11 PM: Open TOT File : C:\H815\LGH815AT-00-V10h-GLOBAL-COM-AUG-25-2015+0.tot 5/5/2016 10:15:11 PM: Model : LG-H815 5/5/2016 10:15:11 PM: SwVersion : LGH815AT-00-V10h-GLOBAL-COM-AUG-25-2015+0 5/5/2016 10:15:11 PM: BuildTime : 5/5/2016 10:15:11 PM: Total Files : 68 5/5/2016 10:15:12 PM: Model name: LG-H815 5/5/2016 10:15:12 PM: Software verion: H81520d 5/5/2016 10:15:12 PM: Android verion: 6.0 5/5/2016 10:15:12 PM: IMEI: 357916070363771 5/5/2016 10:17:07 PM: Start direct download mode 5/5/2016 10:17:09 PM: Write "PrimaryGPT" partition #1 of 68 5/5/2016 10:17:11 PM: Write "modem" partition #2 of 68 5/5/2016 10:17:20 PM: Write "pmic" partition #3 of 68 5/5/2016 10:17:22 PM: Write "sbl1" partition #4 of 68 5/5/2016 10:17:24 PM: Write "tz" partition #5 of 68 5/5/2016 10:17:25 PM: Write "sdi" partition #6 of 68 5/5/2016 10:17:27 PM: Write "hyp" partition #7 of 68 5/5/2016 10:17:29 PM: Write "rpm" partition #8 of 68 5/5/2016 10:17:30 PM: Write "aboot" partition #9 of 68 5/5/2016 10:17:32 PM: Write "sbl1bak" partition #10 of 68 5/5/2016 10:17:34 PM: Write "pmicbak" partition #11 of 68 5/5/2016 10:17:36 PM: Write "tzbak" partition #12 of 68 5/5/2016 10:17:37 PM: Write "hypbak" partition #13 of 68 5/5/2016 10:17:39 PM: Write "rpmbak" partition #14 of 68 5/5/2016 10:17:41 PM: Write "abootbak" partition #15 of 68 5/5/2016 10:17:43 PM: Write "sdibak" partition #16 of 68 5/5/2016 10:17:44 PM: Write "persist" partition #17 of 68 5/5/2016 10:17:47 PM: Write "sec" partition #18 of 68 5/5/2016 10:17:48 PM: Skip "rct" partition #19 of 68 5/5/2016 10:17:50 PM: Write "laf" partition #20 of 68 5/5/2016 10:17:55 PM: Write "boot" partition #21 of 68 5/5/2016 10:18:00 PM: Write "recovery" partition #22 of 68 5/5/2016 10:18:05 PM: Write "factory" partition #23 of 68 5/5/2016 10:18:10 PM: Write "raw_resources" partition #24 of 68 5/5/2016 10:18:12 PM: Write "raw_resourcesbak" partition #25 of 68 5/5/2016 10:18:14 PM: Write "system" partition #26 of 68 5/5/2016 10:18:27 PM: Write "system" partition #27 of 68 5/5/2016 10:18:40 PM: Write "system" partition #28 of 68 5/5/2016 10:18:54 PM: Write "system" partition #29 of 68 5/5/2016 10:18:55 PM: Write "system" partition #30 of 68 5/5/2016 10:19:08 PM: Write "system" partition #31 of 68 5/5/2016 10:19:22 PM: Write "system" partition #32 of 68 5/5/2016 10:19:23 PM: Write "system" partition #33 of 68 5/5/2016 10:19:39 PM: Write "system" partition #34 of 68 5/5/2016 10:19:51 PM: Write "system" partition #35 of 68 5/5/2016 10:19:52 PM: Write "system" partition #36 of 68 5/5/2016 10:20:05 PM: Write "system" partition #37 of 68 5/5/2016 10:20:16 PM: Write "system" partition #38 of 68 5/5/2016 10:20:18 PM: Write "system" partition #39 of 68 5/5/2016 10:20:30 PM: Write "system" partition #40 of 68 5/5/2016 10:20:42 PM: Write "system" partition #41 of 68 5/5/2016 10:20:54 PM: Write "system" partition #42 of 68 5/5/2016 10:21:08 PM: Write "system" partition #43 of 68 5/5/2016 10:21:21 PM: Write "system" partition #44 of 68 5/5/2016 10:21:34 PM: Write "system" partition #45 of 68 5/5/2016 10:21:47 PM: Write "system" partition #46 of 68 5/5/2016 10:22:00 PM: Write "system" partition #47 of 68 5/5/2016 10:22:14 PM: Write "system" partition #48 of 68 5/5/2016 10:22:27 PM: Write "system" partition #49 of 68 5/5/2016 10:22:40 PM: Write "system" partition #50 of 68 5/5/2016 10:22:53 PM: Write "system" partition #51 of 68 5/5/2016 10:23:06 PM: Write "system" partition #52 of 68 5/5/2016 10:23:19 PM: Write "system" partition #53 of 68 5/5/2016 10:23:30 PM: Write "system" partition #54 of 68 5/5/2016 10:23:32 PM: Write "system" partition #55 of 68 5/5/2016 10:23:33 PM: Write "system" partition #56 of 68 5/5/2016 10:23:35 PM: Write "system" partition #57 of 68 5/5/2016 10:23:48 PM: Write "system" partition #58 of 68 5/5/2016 10:23:50 PM: Write "system" partition #59 of 68 5/5/2016 10:23:52 PM: Write "system" partition #60 of 68 5/5/2016 10:24:04 PM: Write "system" partition #61 of 68 5/5/2016 10:24:06 PM: Write "system" partition #62 of 68 5/5/2016 10:24:08 PM: Write "system" partition #63 of 68 5/5/2016 10:24:10 PM: Write "system" partition #64 of 68 5/5/2016 10:24:11 PM: Write "system" partition #65 of 68 5/5/2016 10:24:17 PM: Write "cust" partition #66 of 68 5/5/2016 10:24:23 PM: Write "cust" partition #67 of 68 5/5/2016 10:24:25 PM: Write "BackupGPT" partition #68 of 68 5/5/2016 10:24:26 PM: Erase "rct" partition 5/5/2016 10:24:29 PM: Done. 5/5/2016 10:24:29 PM: Elapsed: 562 secs. --> (v9.11) 5/5/2016 10:24:29 PM: The phone flashed 100% but phone stays on LG logo and version not change after flash stays the same.I flashed the phone with LGUP and all was OK. |
You downgrade version. This can brick phone in new LG. You try flash V10h in phone with V20d. -- :) |
yes i know that but its a TOT file and it can be done .As i told you i already flashed the phone with LGUP and phone is downgraded already.6.01 to 5.1 |
In next time try check: erase user data after flash. Post result. -- :) |
BTW i've tried to make firmware TOT from 6.01 and it was successful.I couldn't find 6.01 tot ,that's why i used 5.1 tot from the support. |
