06-11-2015, 22:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | LG E440 unlocking guide to use with Z3X MTK Tool Choose a micro USB cable Open MTK Tool and choose MTK Android Too Install all drivers and activate debug mode. After drivers all full installed power off device Open the backside cover and extract the battery At this time the phone is off without battery, so you shell 1: Choose boot option in E440 is MTK_AllInOne_DA_v7.1408.00.000 2: Press Connect / Read Info / Codes bottom witch will give you about 20 seconds to complete the rest. 3: When counter is decreasing plug the battery while pressing bouth volume bottoms Vol+ and Vol- 4: put battery back to phone without realing the volume bottoms and plug usb micro cable to mobile. 5: All process will automatically start, like this Selected model is:LG E440 Using COMPORT: COM30 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. USB Serial COM Attached to system... COM Port short name : COM31 COM Port full name : LGE AndroidNet USB Serial Port COM Port hardware id : USB\VID_1004&PID_61F1&REV_0100&MI_02 Open port COM31... Send start CMD commands...done Read HW_CODE...done HW_CODE: 0x6575 Read HW_SW_VER...done HW_SUB_CODE: 0x8A00 HW_VER: 0xCB00 SW_VER: 0xE201 GetEntryRegion...done Disable WDT...done Send DA Agent...done Jump to DA...done Wait DA response...done Send storage device and external ram device config...done Detect NAND Flash...done Get target inforamtion...done Booting OK EMMC Config: EMMC rpmb size: 2048kb EMMC boot1 size: 2048kb EMMC boot2 size: 2048kb EMMC user area size: 3696 Mb Read logical partitions info...done Totally detected partitions: 28 Searching security blocks...ok Reading Security...done IMEI A: 35263606069415 IMEI B: 35030526000000 Bluetooth address:F8A9D0E4D444 Wi-Fi MAC address:CCFA00E063E1 LG SVN1: LGE440AT-00-V10c-268-06-TM3-APR-15-2014+0 LG SVN2: LGE440AT-00-V10c-TM3-PT-APR-15-2014+0 NCK: 9481743040289149 NSCK: 1836621277321716 SPCK: 3825978740435166 CCK: 3702084558303818 SIM: 7364133154319128 HCK: 0000000000000000 Backup are saved into Backups\Backup__35263606069415_SEC.BIN done Read Info OK and thats all done for getting all level codes now we have to manually unlock the phone by powering it on and making the folowing operation How to enter code in LG E440 To enter the unlock code into LG E440 do: 1. Power on your LG E440 with the original SIM card in. 2. Enter 2945#*440#. 3. A menu will pop up, select SIM Unlock or network lock. 4. Enter your NCK unlock code and hit OK. 5. Your LG E440 may automatically reboot. 6. Now phone is unlocked. Hope to have helpped |
The Following User Says Thank You to Rui Romano For This Useful Post: |
07-06-2015, 12:09 | #2 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Serbia
Member: 2334138 Status: Offline Thanks Meter: 78 | LG E440 unlock done Z3X MTK Tool Thank you! ------------------------------------ Selected model is:LG E440 Using COMPORT: COM42 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. USB Serial COM Attached to system... COM Port short name : COM42 Using COMPORT: COM79 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. USB Serial COM Attached to system... COM Port short name : COM80 COM Port full name : LGE AndroidNet USB Serial Port COM Port hardware id : USB\VID_1004&PID_61F1&REV_0100&MI_02 Open port COM80... Send start CMD commands...done Read HW_CODE...done HW_CODE: 0x6575 Read HW_SW_VER...done HW_SUB_CODE: 0x8A00 HW_VER: 0xCB00 SW_VER: 0xE201 GetEntryRegion...done Disable WDT...done Send DA Agent...done Jump to DA...done Wait DA response...done Send storage device and external ram device config...done Detect NAND Flash...done Get target inforamtion...done Booting OK EMMC Config: EMMC rpmb size: 2048kb EMMC boot1 size: 2048kb EMMC boot2 size: 2048kb EMMC user area size: 3696 Mb Read logical partitions info...done Totally detected partitions: 28 Searching security blocks...ok Reading Security...done IMEI A: 35649005385103 IMEI B: 35030526000000 Bluetooth address:30766FC3C7CC Wi-Fi MAC address:58A2B5C0D5AC LG SVN1: LGE440AT-01-V10a-220-05-JUL-12-2013+0 LG SVN2: LGE440AT-00-V10a-220-05-JUL-12-2013+0 NCK: 8691823862891638 NSCK: 6553151459205098 SPCK: 2237863751034718 CCK: 5362745080409929 SIM: 3334870724017505 HCK: 0000000000000000 Backup are saved into Backups\Backup__35649005385103_SEC.BIN done Read Info OK |
03-12-2016, 15:01 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | No need to press anything,only connect micro usb to power off phone and wait to start detecting software. Last edited by galijus; 03-12-2016 at 15:09. |
