08-27-2018, 09:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 328 | SM-N920C Pattern lock Remove Done but No DATA :-( i remove pattern lock with Z3x phone was locked with frp so i remove frp by UART Code: [ 8/27/2018 12:51:58 PM ] Operation: Reset FRP UFS [ 8/27/2018 12:51:58 PM ] Selected model: SM-N920C [ 8/27/2018 12:51:58 PM ] Selected port: COM20 Z3X BOX Serial Port [ 8/27/2018 12:51:58 PM ] Software version: 33.5 [ 8/27/2018 12:51:58 PM ] [ 8/27/2018 12:51:58 PM ] Hold 'Vol down' and press 'POWER ON' for 2-3 seconds [ 8/27/2018 12:51:59 PM ] Checking phone at COM20 OK [ 8/27/2018 12:52:02 PM ] Phone detected, do not release 'Vol down' [ 8/27/2018 12:52:02 PM ] Reading data from phone... OK [ 8/27/2018 12:52:05 PM ] Release 'Vol down' now [ 8/27/2018 12:52:08 PM ] Comparing selected model... match (N920C) [ 8/27/2018 12:52:10 PM ] Setup connection... OK [ 8/27/2018 12:52:10 PM ] Reseting FRP... OK [ 8/27/2018 12:52:11 PM ] Rebooting phone... OK [ 8/27/2018 12:52:12 PM ] Reset FRP done then i erase lock pattern Code: [ 8/27/2018 12:54:53 PM ] [ 8/27/2018 12:55:09 PM ] Operation: Reset Pattern Lock [ 8/27/2018 12:55:09 PM ] Selected model: SM-N920C [ 8/27/2018 12:55:09 PM ] Selected port: COM20 Z3X BOX Serial Port [ 8/27/2018 12:55:09 PM ] Software version: 33.5 [ 8/27/2018 12:55:10 PM ] [ 8/27/2018 12:55:13 PM ] Checking local file... not found [ 8/27/2018 12:55:13 PM ] Searching server... OK [ 8/27/2018 12:55:14 PM ] Downloading file... OK [ 8/27/2018 12:57:19 PM ] Checking local file... OK [ 8/27/2018 12:57:19 PM ] Searching USB Flash interface... COM42 detected [ 8/27/2018 12:57:20 PM ] Setup connection... OK [ 8/27/2018 12:57:21 PM ] Reading data from phone... OK [ 8/27/2018 12:57:21 PM ] Sending data to phone... OK [ 8/27/2018 12:57:22 PM ] Sending data to phone... OK [ 8/27/2018 12:57:24 PM ] Waiting ADB device... OK [ 8/27/2018 12:57:46 PM ] Reading phone info... [ 8/27/2018 12:57:46 PM ] Recovery build version: 6.0.1 [ 8/27/2018 12:57:46 PM ] Boot version: N920CXXU3CQG1 [ 8/27/2018 12:57:47 PM ] Platform: exynos7420 [ 8/27/2018 12:57:47 PM ] Boot serial: 83f0535655565542 [ 8/27/2018 12:57:47 PM ] Product board: zenlte [ 8/27/2018 12:57:51 PM ] Erasing locks... OK [ 8/27/2018 12:57:52 PM ] Rebooting phone... OK [ 8/27/2018 12:57:53 PM ] Reset locks done even storage memory is full with system img......... showing full memory is 4GB and system& user data : 3.9GB I cant reset this phone, customer need data.. please help |
08-28-2018, 08:26 | #3 (permalink) |
Freak Poster Join Date: Mar 2013 Location: In your Mind Age: 35
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 159 | Please flash again with same version and same binary on your phone ( without userdata). Your data will back again Sent from my iPhone using Tapatalk |
The Following User Says Thank You to saifulhaq28 For This Useful Post: |
08-29-2018, 06:40 | #5 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | That's why it's best to do as much as you can manually - without box. Remove FRP with box and then remove screen lock manually Last edited by blang; 08-29-2018 at 08:53. |
