09-26-2010, 10:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india-gujrat-nadiad
Member: 384984 Status: Offline Thanks Meter: 456 | s5610 successfull unlock..by z3x in pc from server z3x 1 down load this file from z3x server ( CSC_S5620ODDJC1) 10 mb ( CODE_S5620DDJC1) 10 mb 2 connect phone in download mode. (for download mode prees volum down key then press power on) 3 connect cable to pc with phone . 4 clock on port serch on multi loder. 5 phone port will select by exe . 6 click on full download of m d exe. 7 select boot filr folder .after select all file as on image 8 click on download 9 within 5 to 8 minut flace will complit . 10 after flace run z3x softwere select model 5620 11 select all file as on image 3 . 12 click on direct unlock yr phone will unlock enjoy & earn mony |
01-23-2013, 16:22 | #3 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | S5610 unlocked done.... Code: Selected model: S5610 Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35817304807948 Phone SW: S5610BVKL1 Phone BT ADDR: 183F-47-124251 Phone SN: R21C503K33 [FREZEE]:36795530 [NET LOCK]:40154510 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:10573 [Activa LOCK]:00000000 [Phone LOCK]:12345 Read info - ok Elapsed time: 26 second, sw ver: 3.5.0040 |
The Following User Says Thank You to sebY7676 For This Useful Post: |
01-23-2013, 19:10 | #5 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Good Work Mate. BR. Arsalan gsm2000. |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
06-01-2013, 09:04 | #7 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | Code: Selected model: S5610 Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35817304851807 Phone SW: S5610BVKL1 Phone BT ADDR: 18E2-C2-91E6DE Phone SN: R21C529HR0 [FREZEE]:86949320 [NET LOCK]:36573660 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 11 second, sw ver: 3.5.0040 |
09-13-2013, 15:00 | #8 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1652459 Status: Offline Thanks Meter: 22 | Use cable B3210 (micro uart+usb) select z3x port Selected model: S5610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35526405xxxxyy Phone SW: S5610BVKL1 Phone BT ADDR: 50F5-20-3C880B Phone SN: R21D26EQHV [FREZEE]:188xxxx [NET LOCK]:1002xxxx [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 22 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
04-10-2014, 19:24 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Yea i make a video about unlocking with uart http://www.youtube.com/watch?v=V62LH0CDpyQ Sent from my GT-I8190N using Tapatalk |
04-15-2014, 10:56 | #10 (permalink) |
Member: 1652459 Status: Offline Thanks Meter: 22 | with c3300k microuart cable Selected model: S5610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 3594xxxxxxxxxx Phone SW: S5xxxxVML1 Phone BT ADDR: BC44-86-C2173B Phone SN: R21xxxxx5V [FREZEE]:1xxxx350 [NET LOCK]:79xxx400 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 14 second, sw ver: 3.5.0040 |
05-05-2014, 14:54 | #11 (permalink) |
Member: 1652459 Status: Offline Thanks Meter: 22 | c33ook cable Selected model: S5610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 353630xxxxx Phone SW: S5610BVKL1 Phone BT ADDR: 04FE-31-286DA1 Phone SN: R21C87xxxx [FREZEE]:30135200 [NET LOCK]:68082110 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 28 second, sw ver: 3.5.0040 ------------------------------------------------------ |
06-05-2015, 14:56 | #13 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1817436 Status: Offline Thanks Meter: 18 | unlock done !!! Samsung S5610 with Z3X Use rj45 C3300k cable with the phone OFF , press read codes and insert C3300k cable . elected model: S5610 Selected com port: COM7 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 356939xxxxxxxxxx Phone SW: S5610Bxxxxxx Phone BT ADxxx: 10D5-42-7C3xxx1 Phone SN: Rxx57xxxxxx [FREZEE]:14260620 [NET LOCK]:08708250 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 10 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
09-10-2015, 09:21 | #14 (permalink) |
Member: 1652459 Status: Offline Thanks Meter: 22 | with c3300k microuart cable again: Selected model: S5610 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 3552xxxxxxx Phone SW: S5610XXMA1 Phone BT ADDR: 50F5-20-37xxxx Phone SN: R21xxxxxx [FREZEE]:16069090 [NET LOCK]:480xxxx [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:12345 Read info - ok Elapsed time: 10 second, sw ver: 3.5.0040 |
02-03-2017, 19:45 | #15 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | Z3X says phone is unlocked, but not unlocked, insert correct sim card showing..! why?? Selected model: S5610 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35817304860239 Phone SW: S5610XXKK1 Phone BT ADDR: 18E2-C2-999F4A Phone SN: R21C52KAWQ All code change to -> 00000000 If phone lock enter code -> 00000000 Unlock - ok Elapsed time: 14 second, sw ver: 3.5.0040 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
