12-07-2017, 13:11 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | J330f unlock fail Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever ('Diag' algo): Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever ('Upload' algo): Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J330F Software version: 30.1 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J330F Android version: 7.0 Product code: SM-J330FZDDXSG Phone version: J330FXXU1AQFB PDA version: J330FXWU1AQF9 CSC version: J330FOJV1AQF9 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: R58J82VJ35R Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-06-01 RF cal date: 20170812 IMEI: 358870083824189 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM10 detected Calculating... error (1) Done with Samsung Tool PRO v.30.1 |
12-14-2017, 14:41 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
just solution will ready we will add to update. | |
12-21-2017, 17:13 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Hello but I have done this phone unlock and now all is ok. Waiting for server answer... OK Freeze code: 40919637 NET lock: 05269319 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
