LG LS775 stuck in download mode in unlocking LG 2-3G Tool v9.30 supported models: 1426 Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.30) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.30) Checking phone at COM624 Detected ID: 00000FFE (MSM8916) SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 Reading ESN... OK Read SPC... Unlock SPC... error Elapsed: 1 secs. --> (v9.30) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:30:30:30:30 Phone Code: Elapsed: 1 secs. --> (v9.30) Checking phone at COM624 Detected ID: 00000FFE (MSM8916) SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 Reading ESN... OK Read SPC... Unlock SPC... error Elapsed: 1 secs. --> (v9.30) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.30) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:30:30:30:30 Phone Code: Elapsed: 1 secs. --> (v9.30) Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Start unlock Sprint... Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304076470224 Backup carrier... done Init EXT4 ... /apps /apps/node.db /apps/node.db-journal Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /cust... Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /omadm... Save EXT4... Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]]. Elapsed: 45 secs. --> (v9.30) |
Me too. Octoplus doesn't mess up the phone like this. Kindly fix this problem asap! LG 2-3G Tool v9.32 supported models: 1440 Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 356304079xxxxxxx BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.32) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 356304079xxxxxxxx BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.32) Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Start unlock Sprint... Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304079xxxxxx Backup carrier... done Init EXT4 ... /apps /apps/node.db /apps/node.db-journal Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /cust... Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /omadm... Save EXT4... Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]]. Elapsed: 53 secs. --> (v9.32) |
waiting for support answer i want to restore back in Normal state if we cant unlock :( i downloaded its tot https://forum.xda-developers.com/and...-0-lg-t3552990 but z3x unable to flash :( always same error battery 50% charged 2/9/2017 8:44:59 PM: LG 2-3G Tool v9.32 2/9/2017 8:44:59 PM: supported models: 1440 2/9/2017 8:44:59 PM: 2/9/2017 8:48:02 PM: Reading timeout, check cable 2/9/2017 8:48:02 PM: Error Code: ReadInfo,1,1 2/9/2017 8:48:02 PM: Elapsed: 2 secs. --> (v9.32) 2/9/2017 8:48:02 PM: 2/9/2017 8:49:48 PM: Reading timeout, check cable 2/9/2017 8:49:48 PM: Error Code: ReadInfo,1,1 2/9/2017 8:49:48 PM: Elapsed: 2 secs. --> (v9.32) |
Flashing mine with same file. Its currently at 40%. You should charge battery at external source before flashing. It will work. |
It looks like the unlock process messes with a partition, which makes it get stuck in download mode. Repartition during flash process should change that. |
Process is done sucessfully. Phone is back to working state. LG 2-3G Tool v9.32 supported models: 1440 Mode: Emergency Model: LS775 Read info... Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304079xxxxxxxx Elapsed: 2 secs. --> (v9.32) Phone mode is DOWNLOAD Start flashing. Open TOT File : M:\Work\LG\LS775\LS775ZV8_07.tot Model : LGLS775 SwVersion : LS775ZV8 BuildTime : Total Files : 22 Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304079xxxxxxx Laf flash error: incompatible partition table [start] 01D56000:01D5BFDD, grow Start direct download mode Write "PrimaryGPT" partition #1 of 22 Write "sbl1" partition #2 of 22 Write "tz" partition #3 of 22 Write "hyp" partition #4 of 22 Write "rpm" partition #5 of 22 Write "aboot" partition #6 of 22 Write "sbl1bak" partition #7 of 22 Write "tzbak" partition #8 of 22 Write "hypbak" partition #9 of 22 Write "rpmbak" partition #10 of 22 Write "abootbak" partition #11 of 22 Write "persist" partition #12 of 22 Write "metadata" partition #13 of 22 Write "laf" partition #14 of 22 Write "boot" partition #15 of 22 Write "recovery" partition #16 of 22 Write "recoverybak" partition #17 of 22 Write "sec" partition #18 of 22 Write "factory" partition #19 of 22 Write "modem" partition #20 of 22 Write "carrier" partition #21 of 22 Write "system" partition #22 of 22 Erase "rct" partition Done. Elapsed: 286 secs. --> (v9.32) Make sure to boot to recovery mode and do hard reset to prevent force close of settings app after flashing |
can you please share the flash file??? |
please share the flash file, link not working.... thaks |
thanks |
Here it is: Download LS775ZV8 zip |
i can flash this file in zv9 , my phone stuck in logo but have zv9 |
You can't more unlock Sprint phone with Android 7 because LG add firmware sign. You can't write in phone only signed firmware. For repair phone: Put phone in Download mode Reflash with last firmwares -- :) |
downgrade is possible Quote:
can you share the firmware pls....LS775ZV5 |
