09-12-2018, 16:58 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: At Work always
Member: 885483 Status: Offline Thanks Meter: 15 | SM-G950U unlock error [Answered] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Software version: 33.8 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQS5CRH1 CSC version: G950UOYN5CRH1 Phone version: G950USQS5CRH1 Product code: SM-G950UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J43KLNHD IMEI: 355987082400010 HW version: REV1.0 RF cal date: 2017.04.25 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-08-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM19 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM13 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.8 |
09-13-2018, 19:20 | #4 (permalink) |
Member: 885483 Status: Offline Thanks Meter: 15 | also problem with s7 UNLOCK INSTRUCTIONS: To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G930T Software version: 33.8 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 7.0 PDA version: G930TUVS4BQL2 CSC version: G930TTMB4BQL2 Phone version: G930TUVS4BQL2 Product code: Not Active CSC country code: USA CSC sales code: TMB Phone SN: R58H22P2D5Y IMEI: 355916070970494 HW version: MSM8996.00 RF cal date: 2016.02.24 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-12-01 Boot Warranty bit: 0 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM12 detected Reading data from phone... OK Calculating... error (4) Done with Samsung Tool PRO v.33.8 |
09-15-2018, 21:11 | #9 (permalink) |
Insane Poster Join Date: Nov 2008 Location: Kras
Member: 892657 Status: Offline Thanks Meter: 1 | Hi. Any update? Am have this same error. Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQS5CRH1 CSC version: G950UOYN5CRH1 Phone version: G950USQS5CRH1 Product code: SM-G950UZVATMB CSC country code: USA CSC sales code: TMB Phone SN: RF8J82YTWDK IMEI: 353112XXXXXXXXX HW version: REV1.0 RF cal date: 2017.08.24 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-08-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM50 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM51 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.8 |
09-21-2018, 05:38 | #10 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,274 | Quote:
The Following User Says Thank You to souma_k For This Useful Post: |
