Lg m200n successfully unlocked with z3x lg m200n successfully unlocked with z3x here logs Checking phone at COM835 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00008-8937_GENNS_PACK-1 Reading ESN... OK Read SPC... Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Model name: LG-M200n Software verion: M20010f Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 3549650xxxxxx Save part1... done Save part2... done Save part3... done Sec zone saved: ..\Backup\M200N_354965081xxxxxx_26082017_173457.lg sb1 Write security zone... Erase part1... done Erase part2... done Erase part3... done Reboot... Phone detected! Reading QCN file... OK Checking phone at COM835 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00008-8937_GENNS_PACK-1 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Unlock done! Elapsed: 344 secs. --> (v9.39) ZUBAIR |
HI How you connect lg m200n ,there is no help file thanks |
turn on usb tethering ....... zubair |
thank you for your answer and time but problem was in diag port enabling because like i said there is no help file i i use help file from m210 model |
PC detect any interface from this phone? Try install LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe and connect in Charge Only, PTP, MTP mode. PC must detect LG port. -- :) |
no andrew it was useless trying but after *#546368#*200# and port check test enabled everything is fine of course also imei 0 fix needed |
and if you are not new in all latest lg phones you have to enable port check on thanks |
M200n qcn Quote:
Problem with phone connection (do you enable diag port?). Check drivers, cable, try in another PC. -- :) |
i also have problem with this model ..i enable port check test but computer dont see him as a port...what is the solution |
1. Install LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe driver. 2. Connect phone in Charge only or MTP mode. -- :) |
thanks it works...but what should i do, z3x freeze when imei changing |
