10-06-2018, 20:09 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | SM-G570F custom binary blocked by frp lock got device stuck on custom binary blocked by frp lock with red color just download mode work flashed these firmware G570FXXU1BQJ1_G570FOJV1BQJ1_XSG 7 flash ok same issue G570FXXU1AQH6_OJV1AQH2_ 6.0.1 flash ok same issue G570FDDU1BQI6 7 flash error frp lock tried with pit file and without even tried nand erase same issue efs clear all done but same isssue phone SN R58J65ZPQJ MODEL G570 DS IN DOWNLOAD MODE B1 K0 S0 CURRENT BINARY CUSTOM SYSTEM STATUS CUSTOM TRIED COMB FILE ALSO SAME ISSUE |
10-07-2018, 06:36 | #4 (permalink) | |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Quote:
<OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/024> Removed!! <ID:0/024> Added!! <ID:0/024> Odin engine v(ID:3.1301).. <ID:0/024> File analysis.. <ID:0/024> Total Binary size: 3900 M <ID:0/024> SetupConnection.. <ID:0/024> Initialzation.. <ID:0/024> Set PIT file.. <ID:0/024> DO NOT TURN OFF TARGET!! <ID:0/024> Get PIT for mapping.. <ID:0/024> Firmware update start.. <ID:0/024> NAND Write Start!! <ID:0/024> SingleDownload. <ID:0/024> sboot.bin <ID:0/024> param.bin <ID:0/024> cm.bin <ID:0/024> boot.img <ID:0/024> recovery.img <ID:0/024> system.img <ID:0/024> userdata.img <ID:0/024> modem.bin <ID:0/024> Transmission Complete.. <ID:0/024> Now Writing.. Please wait about 2 minutes <ID:0/024> Receive Response from boot-loader <ID:0/024> cache.img <ID:0/024> hidden.img <ID:0/024> RQT_CLOSE !! <ID:0/024> RES OK !! <ID:0/024> Remain Port .... 0 <ID:0/024> Removed!! <OSM> All threads completed. (succeed 1 / failed 0) same issue | |
10-07-2018, 19:11 | #5 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | i flashed 6.0.1 with pit stuck on logo flashed 7 reach recovery and install update at 2% then reboot flashed 8.0.0 install update erase but end with error here photo |
