LG MS428 pattern lock I have a LG MS428 and cant remove pattern lock. Really not that familar with the LG line Yet. the phone is Metro PCS. I put the phone in download mode. LG 2-3G Tool v9.25 supported models: 1380 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.25) I cant find a root for this phone????? |
Hi, Select H900 for example, Put phone in download mode, Press Reset Screen Lock button -- :) |
LG MS428 pattern lock this is what i keep getting LG 2-3G Tool v9.25 supported models: 1380 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.25) Not detect phone! Please manual select port or reboot PC! does the phone have to be rooted? Should i be connected to the z3x box or PC? |
Should be connected to the PC Search phone Press Reset Screen Lock button |
You install LG driver? PC detect LG port? -- :) |
LG MS428 pattern lock Mode: Emergency Model: MS428 Elapsed: 2 secs. --> (v9.25) Phone mode is DOWNLOAD Start reset screen locks... Model name: LGMS428 Software verion: MS42810c Android verion: 6.0.1 IMEI: 358479073352084 Truncate file 0... Laf flash ext4 error: could not find inode for "/system/backuppin.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 1... Laf flash ext4 error: could not find inode for "/system/gesture.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 2... Laf flash ext4 error: could not find inode for "/system/password.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 3... done Truncate file 4... done Truncate file 5... done Screen locks removed. Elapsed: 42 secs. --> (v9.25) It has a APP called 360 security and I think that is what gives the pattern lock. Also now its stuck on the boot logo Metro Pc. when i try to factory reset the phone the program just locks up. |
If phone still Goes download mode Flash same Software verion: MS42810c Post result. |
You need reflash phone with checked: flash in direct mode erase user data after flash 360 security this not standard app. -- :) |
LG MS428 pattern lock I reflashed the firmware and now it boots ok but still have pattern lock with 360 security. |
LG MS428 pattern lock Mode: Emergency Model: MS428 Elapsed: 2 secs. --> (v9.25) Phone mode is DOWNLOAD Start flashing. Open KDZ File : C:\Users\NEW\Desktop\LG MS428\MS42810c_00_0514.kdz Model : LGMS428 SwVersion : MS42810c BuildTime : 0000-00-00 00:00:00 Total Files : 52 Model name: LGMS428 Software verion: MS42810c Android verion: 6.0.1 IMEI: 358479073352084 Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. Start indirect download mode. Sending image... Verifying image... Checking image... Flashing image... Done. Elapsed: 219 secs. --> (v9.25) |
2. I write you in post: Quote:
LG MS428 pattern lock I was able to remove 360 app security. 1st long press on the settings icon and drag it to the bottom bar. 2nd long press the settings icon and look for the 360 app and drag it to the uninstall location at top of screen. thats it the pattern lock is gone. I want to thank every body for there help. Oh by the way how do you unlock this phone. |
Same issue trying to remove PIN lock from same model (normal PIN lock, not "360 security app"). Unable to get comport information , check system LG 2-3G Tool v9.27 supported models: 1397 Mode: Emergency Model: MS428 Elapsed: 2 secs. --> (v9.27) Phone mode is DOWNLOAD Start reset screen locks... Model name: LGMS428 Software verion: MS42810c Android verion: 6.0.1 IMEI: Truncate file 0... Laf flash ext4 error: could not find inode for "/system/backuppin.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 1... Laf flash ext4 error: could not find inode for "/system/gesture.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 2... Laf flash ext4 error: could not find inode for "/system/password.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 3... done Truncate file 4... done Truncate file 5... done Screen locks removed. Elapsed: 50 secs. --> (v9.27) And phone stuck on Metro PCS logo and does not advance from there. Assistance needed please |
- flash in direct mode - erase user data after flash. -- :) |
