Old 02-06-2018, 11:21   #1 (permalink)
Member: 2429352
Thanks Meter: 72
SM-A520F unlock faied 2018 B4
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Operation: Read Codes via Server
Selected model: SM-A520F
Software version: 30.7
Checking Login and Password... OK
Ballance: 15 crd.
You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM27
Reading phone info... OK
Model: SM-A520F
AP version: A520FXXU4BRA8
CSC version: A520FOLE3BRA8
CP version: A520FXXU4BRA9
Product code: XID
Phone SN: R58J92AFDXR
Unique number: CBJ00C560FA0674
Searching Samsung diag port... detected COM25
CP build: Jan 5 2018 18:26:02
Reading data from phone... error (1)
Done with Samsung Tool PRO v.30.7
Old 03-21-2018, 13:22   #2 (permalink)
Member: 2655726
Thanks Meter: 7
i have same problem !! Any solution ?
Old 04-04-2018, 08:01   #3 (permalink)
Member: 490719
Thanks Meter: 4
same here. already try via msl and still error 1.
Searching Samsung modem... detected COM10
Model: SM-A520F
AP version: A520FXXU4BRB1
CSC version: A520FOXX4BRAH
CP version: A520FXXU4BRAH
Product code: SEB
Phone SN: R5xxxxx
Unique number: CBJ10B146F43A34
Reading IMEI... OK
IMEI: 35xxxxx
Reading SN... error (1)
Done with Samsung Tool PRO v.31.0
Page generated in 0.13561 seconds with 8 queries
