07-07-2009, 14:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Prizren
Member: 841080 Status: Offline Thanks Meter: 177 | LG U370 Not start after flash with flash file from support???? |
07-07-2009, 14:53 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Hi , press 2+5 and power , then flash it again in emergency mode , it will be very good if you provide log of operation and say what operator brand fw installed before flashing. |
07-07-2009, 16:11 | #3 (permalink) |
Member: 841080 Status: Offline Thanks Meter: 177 | i flash it in emergecy mode here is the log :: 7/7/2009 14:54:31: v.1.5.4 7/7/2009 14:54:31: supported models: 61 7/7/2009 14:54:31: andrew_tm 2009(c) 7/7/2009 14:54:31: 7/7/2009 14:54:58: Reading file as U370... 7/7/2009 14:55:03: Original Flash File: 7/7/2009 14:55:03: U370-V10a-OCT-15-2007-H3G-IT 7/7/2009 14:55:03: 7/7/2009 14:55:38: Mode: Emergency 7/7/2009 14:55:38: Model: U370 7/7/2009 14:55:38: Elapsed: 0 secs. 7/7/2009 14:55:38: 7/7/2009 14:55:55: Start Flash... 7/7/2009 14:55:55: Modem Write Start... 7/7/2009 15:08:17: Flash Verify Done. 7/7/2009 15:08:18: EFS Erase Done. 7/7/2009 15:08:18: Modem Write Done. 7/7/2009 15:08:18: Phone Reboot. 7/7/2009 15:09:01: Phone Detected! 7/7/2009 15:09:02: EFS Write Start... 7/7/2009 15:09:02: Start Write Media... 7/7/2009 15:14:21: Start Write Module... 7/7/2009 15:18:39: EFS Write Done. 7/7/2009 15:18:39: Flash Done. 7/7/2009 15:18:39: Elapsed: 1364 secs. everythink show ok but why not start i dont know!!!!!!!!! |
07-09-2009, 12:27 | #6 (permalink) | |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
I send you FW and Factoy Downloader , maybe it help. | |
04-01-2012, 15:48 | #7 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
Please Give Me U370 Factory Firmware / Down-loader Now i'm Boor Reason Trying it Flashing ..... But Set Still Blinking Problem When i Try it For Flashing Showing This :- Code: LG 2-3G Tool v2.4 build 00FA supported models: 503 Mode: Emergency Model: U370 Elapsed: 0 secs. --> (v2.4 build 00FA) Reading file as U370... Ok Original Flash File: U370-V10a-OCT-15-2007-H3G-IT Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 0 secs. --> (v2.4 build 00FA) | |
04-01-2012, 16:03 | #8 (permalink) | |
After Trying Result What can i Do Now About this Set... Code: LG 2-3G Tool v2.4 build 00FA supported models: 503 Mode: Emergency Model: U370 Elapsed: 0 secs. --> (v2.4 build 00FA) Reading file as U370... Ok Original Flash File: U370-V10a-OCT-15-2007-H3G-IT Mode: Emergency Model: U370 Elapsed: 0 secs. --> (v2.4 build 00FA) Start Flash... Modem Write Start... Reading timeout, check cable Error Code: CmdSendPartitionTable Error CmdSendPartitionTable Modem file flash error! Elapsed: 7 secs. --> (v2.4 build 00FA) | |
04-02-2012, 09:00 | #10 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Bro:- My Cable is Tested When Press 2+5 inset Usb 2 Pc Modem Port Found Always Battery Was Fully Charge. I Think Z3x Cant Write This Set Flash i Have Doubt bug with this version. if You Can give me Original dz Format Firmware. thanks in advance |
04-02-2012, 09:13 | #11 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | This phone write firmware same algo how cu500 and more other and algo work. I have dz firmware but backing to office only in friday. -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
KP100go dead after flash with kp100 file from support | *phone-company* | VygisToolbox | 18 | 02-11-2011 09:54 |
GW620 can`t flash with unock file from support | valiu | Octopus LG/Octoplus LG | 4 | 03-22-2010 15:28 |
LG KE500 flash file from support not working!!! | riccardo2001200 | UST Pro II | 0 | 09-20-2008 14:15 |
u890 hangs on 3g logo after flashed with 64k file from support please help | amit_varietymob | FuriousGold | 0 | 09-03-2008 11:32 |
p;roblem with opening file from support | bulid | MT-BOX | 13 | 05-21-2007 16:36 |
