LG V10 Port Check Test? I have a LG V10 At&t H900 phone. For me to service the phone I need to enable the diagnostic port by enabling the port check test in the service menu. Does anyone know what keys to type in? 277634#*# does not work 3845#*900# does not work Thanks in advance Gene |
download and install this software. Check code how show sotfware. -- :) |
Thank you for your reply. The codes in the app don't work for this At&t LG V10 phone I have. How did you guys do it? Obviously you guys got it to work since you put IMEI service option in 8.8 update for H900 phone. Please let me know what key input to dial in phone. Thanks in advance Gene |
Any news on this ? I have one to same thing need to enable port check test but no codes work |
Root phone after root enable diag. -- :) |
do you know of root solution for the at&t H900 I've only found for the H901 |
still no port test method? please help i have a h900 |
Kinguser 4.6.2.apk try root using this root apk. -- :) |
Or use this code: *#546368#*900#-> Port check Test -> set Enable. -- :) |
i enable port but still no port on device manger only portable showing |
Connect phone in Charge or MTP mode. Install latest LG driver( LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe) -- :) |
cant enable in lg g4 stylus cant enable in lg g4 stylus only disable screen in svc screen |
Code: su :) |
