LS992 unlock problem Hi I have problem with sprint unlock Mode: Emergency Model: LS992 Elapsed: 3 secs. --> (v9.25) Phone mode is DOWNLOAD Start unlock Sprint... Model name: LGLS992 Software verion: LS992ZV3 Android verion: 6.0.1 IMEI: 35*********26 Backup carrier... done Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /cust... Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /omadm... Unlock done! Elapsed: 7 secs. --> (v9.25) Tried flash firmware, factory reset still the same Another one with the same version ZV3 unlock ok BR Tomi |
1. Connect other LS992 in Download mode. 2. Press Firmware Maker and check only Carrier partition. 3. After read you get tot file. 4. Write this tot file in your phone with unlock problem and try make unlock. 5. Post result. -- :) |
Still the same error readed carrier, flashed ok unlock error BR Tomi |
from cant unlock Do I have to read from good one and write to bad? |
Yes! :) I write this 2 post before! :) -- :) |
:-) ok I see I did it, unlock ok, but no network on both How can I eneble gsm networks, menu is only CDMA or LTE/CDMA thnx |
In both is problem with network |
You need download this app https://play.google.com/store/apps/d...idden.settings and change Network from app. -- :) |
Thank you, network is ok now but data not work ( apn is set correctly) |
Can z3x backup a tot??? |
But you can write tot backup only in phone without signed firmware. -- :) |
LS992 Android 7.0 I use firmmaker to create a tot firmware,then I flash this rom.It shows error as below.. LG 2-3G Tool v9.34 supported models: 1445 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.34) Mode: Emergency Model: LS992 Read info... Model name: LGUS992 Software verion: US99223a Android verion: 7.0 IMEI: 355602073577037 Elapsed: 6 secs. --> (v9.34) Mode: Emergency Model: LS992 Read info... Model name: LGUS992 Software verion: US99223a Android verion: 7.0 IMEI: 355602073577037 Elapsed: 4 secs. --> (v9.34) Phone mode is DOWNLOAD Start flashing. Open TOT File : C:\Users\Administrator\Desktop\US99223a_03.tot Model : LGUS992 SwVersion : US99223a BuildTime : Total Files : 42 Model name: LGUS992 Software verion: US99223a Android verion: 7.0 IMEI: 355602073577037 Start direct download mode Write "PrimaryGPT" partition #1 of 42 Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]]. Direct download error. Flashing error. Elapsed: 12 secs. --> (v9.34) |
