Old 04-22-2019, 13:48   #16 (permalink)
tausifawais's Avatar
Member: 1242837
Sonork: 100.1653310
Thanks Meter: 53
Search Adb device....
>> Device Found!
Reading Info............
MANUFACTURER : SAMSUNG
HARDWARE : QCOM
MODEL : SM-G935T
BASEBAND : MSM
BOARD : MSM8996
VERSION : 7.0
DEVICE TYPE :
COUNTRY CODE :
CONNECTION MODE : MTP,ADB
Repair Mipi Success!!
Hints : Popup Will Show , Go Setting , System , And Go To Rebuild Nvrm Then Reboot
this method is 1000% working for me...... my set was mipi device failled error...
and now
my set is 100 % working fine..... this is money making.... post......
thank
best regards....
Tausif Mughal
The Following 2 Users Say Thank You to tausifawais For This Useful Post:
Old 07-16-2019, 09:43   #17 (permalink)
Member: 2740295
Thanks Meter: 33
Originally Posted by shedeed View Post
Download software from here
https://mega.nz/#!zxJQ1I7R!JkwTAiyG7...f9P1zivLto6Q9g
First Root Phone
connect Phone Run software
Hideen Menu will Pop up on device
Choose NV rebuild
Reboot
Phone done
Ps: Copied
There is another solution manual way but this more easy
Not show Pop-Up on J250F
The Following User Says Thank You to raju24.bd For This Useful Post:
Old 07-16-2019, 10:23   #18 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hey guys..
anyone tested this soluiton on android 9 u9 binary..? no pop up or secret codes not working on u9 binary..
Old 07-23-2019, 10:15   #19 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
install shortcut master lite.
Go to secret code explorer and open 27663368378.
You will be able to navigate from there to NVRAM Rebuild, though youll have to look it up for your device as the menu changes depending on the model and system.
more detail
go to code 27663368378.
click launch 0
ue setting & info
setting
system
nv rebuild
all mode.
reboot and done.
The Following 5 Users Say Thank You to quasim0438 For This Useful Post:
Old 07-25-2019, 16:38   #20 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
2766336837 use this no need root
have to conect phone with z3x urt cable and then u put this code
The Following 2 Users Say Thank You to sweetboy For This Useful Post:
Old 07-25-2019, 16:58   #21 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
File Type: jpg scv_15640689444894919595320926418493.jpg (350.6 KB, 538 views)
The Following User Says Thank You to sweetboy For This Useful Post:
Old 08-08-2019, 08:42   #22 (permalink)
Member: 2692941
Sonork: GULAHMAD
not working on g9350 rooted phone its not recognise adb runs fast says mipi repair success bat not
Old 08-22-2019, 10:35   #23 (permalink)
Member: 2140360
no network
not working on g9350 u4 android 8.0.0 rooted phone its not recognise adb
Old 08-26-2019, 16:46   #24 (permalink)
ky_bAttaUsAi's Avatar
Member: 919402
Sonork: ky
Thanks Meter: 93
Thanks you are The Man, It work with G930A 7.0 binary U4. i try allot of method but only work with this.
more detail
click launch 0
ue setting & info
setting
system
nv rebuild
all mode.
reboot and done.
The Following User Says Thank You to ky_bAttaUsAi For This Useful Post:
Old 09-26-2019, 14:20   #25 (permalink)
behruz_abab's Avatar
Member: 2695998
Thanks Meter: 68
G973 mipi device fail who can repair ??? I can pay (((((((((
The Following User Says Thank You to behruz_abab For This Useful Post:
Old 10-14-2019, 22:46   #26 (permalink)
Member: 1844330
Thanks Meter: 4
for new devices model such s7 and s7 edge and all devices not rooted by cobination file mipi fixed follow:
Fix Mipi Device Fail All New Bulids Tested | Yemen-Pro
The Following User Says Thank You to alsharaby For This Useful Post:
Old 10-16-2019, 09:27   #27 (permalink)
Member: 2905715
Sonork: 100.1682585
Thanks Meter: 11
ihave do this work but not work any other solution frends
1. Flash Combination
2. Put this code
#27663368378#* or
*#33725327#
choose
Setting --- System --- Nv Rebuild --- All
3. Make Reboot
4. Flash From Firmware ( BL + CP + AP )
5.in csc select From Combination Flash Those Files (Cache + HEROLTE.PIT + META.DATA)
The Following 3 Users Say Thank You to Tahir shinwari For This Useful Post:
Old 11-23-2019, 11:06   #28 (permalink)
kachman's Avatar
Member: 272581
Thanks Meter: 118
i can fix g930A/T/U/P and g935a/t/u/p for 15$
Old 01-30-2020, 21:25   #29 (permalink)
Member: 2308999
Sonork: 100.1657583
Thanks Meter: 34
I FIXED THE PROBLEM IN G935A
First flash with G935U FIRMWARE
FLASH ENG MODEM
FLASH STOCK MODEM (from g935u firmware)
PROBLEM FIXED 100%
Old 02-23-2020, 19:48   #30 (permalink)
Member: 2899948
Sonork: 100.640600
make backup qcn then write stock rom and then write qcn
The Following User Says Thank You to khandani For This Useful Post:
Page generated in 0.20355 seconds with 9 queries
