Old 11-14-2013, 02:22   #1 (permalink)
azerty_soft's Avatar
Member: 168313
Sonork: 100.1609490
Thanks Meter: 50
Root & unlock GT-I9082 on Android 4.1.2 & 4.2.2
Install CWM Recovery & Root Samsung Galaxy Grand GT-I9082 on Android 4.1.2 & 4.2.2 [Guide]
Make sure that you have battery charged over 60 % and have backed up all your important Contacts, Call Logs & Messages. It is highly recommended in case of any mishap or data loss to backup all your important data.
Things you need to download:
1. Download Odin PC and install it. - Get it Here
2. Download and install Samsung USB Drivers – Get Here
3. Download the CWM-touch_i9082_chotu.tar.zip - Get it Here and unzip it once.
4. Download the SuperSu.zip file – Get it Here.
5. Download the Fix-Recovery.zip – Get it Here.
How to Install ClockworkMod Recovery on your Galaxy Grand.
1. Boot your phone in the Download mode. In order to do so turn it off by pressing and holding the power key or by pulling out the battery for 30 seconds. Turn it on by pressing and holding Volume Down + Home Button + Power Key simultaneously. You should see a warning now, press Volume Up to continue.
2.
3. Your phone is in download mode now.
4. Open ODIN, connect your phone to your PC using the original data cable which came inside the box.
5. The ID:COM box in the top left corner should turn blue or yellow depending upon your ODIN version now.
6. Select the PDA tab and select the downloaded & extracted CWM-touch_i9082_chotu.tar.zip file here. Make sure that the selections in your ODIN are exactly as shown below.
7. In order to prevent any issues, uncheck the “Auto-Reboot’‘ option in ODIN as it is already selected when you open it.
8.
9. Click start, it should take a few seconds while your phone restarts, as soon as it shows the ”PASS” status remove your phone from the PC and pull out the battery for a few seconds. Put it back and now turn it in booting into the recovery mode by pressing Volume Up + Home Button + Power Key.
10. And you have the CWM recovery installed on your Galaxy Grand Duos!
Now here’s how you can root your Galaxy Grand Duos
1. Place the downloaded SuperSu.zip and Fix-Recovery.Zip files on your phone’s external SDcard (make sure that it’s not on internal).
2. Now boot your phone into the recovery mode. In order to do so, press and hold the Volume Up + Home Button + Power Keysimultaneously. Your phone should now boot into recovery mode.
3. Tap install zip from SDcard > choose zip from sd card and choose the file Fix-Recoery.Zip and let it flash the Fix-Recovery.
4. Tap install zip from SDcard once again, and then choose zip from sd card, this time you need to select SuperSu.zip file and wait for it to flash the SuperSu.
Solving the Issues
Although i’ve written above in the CWM recovery flashing method’s 6th step to uncheck the Auto Reboot option before flashing the CWM recovery, if you still face any issues, or if your phone is gone into the bootloop you may try flashing a stock ROM and try the method once again. Here’s our Full GUIDE on how you can get the latest stock firmware on your Galaxy Grand Duos GT-I9082.
good luck
azerty_soft
The Following 9 Users Say Thank You to azerty_soft For This Useful Post:
Old 02-03-2014, 15:27   #2 (permalink)
adnan_taeki's Avatar
Member: 417778
Sonork: 100.1603326
Thanks Meter: 116
Unlock Done With Z3x after Root
Version 4.2.2
AP: I9082XXUBMHC
CP: I9082XXUBMH1
CSC: I9082OJVBMH3
Selected model: I9082
Selected port: COM84 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Please, allow USB debugging on phone...
Reading phone info...
Model: GT-I9082
Android version: 4.2.2
Product code: Unknown
Phone version: I9082XXUBMH1
PDA version: I9082XXUBMHC
CSC version: I9082OJVBMH3
IMEI: 3590-----------
Phone S/N: RF---------
Checking Super user right... true
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool v.16.5
Regards,
The Following 2 Users Say Thank You to adnan_taeki For This Useful Post:
Old 03-09-2014, 08:56   #3 (permalink)
Member: 1680408
Sonork: 01726604159
Selected port: COM8 Z3X BOX Serial Port
Searching ADB device... OK
Model: GT-I9082
Phone version: I9082XXEBMGA
PDA version: I9082XXUBMGA
CSC version: I9082OXEBMGA
IMEI: 000000000000000
Phone S/N: RF1F114XDMH
Unlocking... OK
Unlock done
Done with Samsung Tool v.17.0
Old 04-05-2014, 13:41   #4 (permalink)
Crazy Poster
Member: 957935
Sonork: 658865
Thanks Meter: 9
brother, all is ok but not don unlock
The Following User Says Thank You to Alihaider For This Useful Post:
Old 05-02-2014, 11:27   #5 (permalink)
Member: 2177797
Sonork: 100.1655224
Thanks Meter: 15
samsung i 908/2 auto enter recovery mode
Old 05-02-2014, 20:06   #6 (permalink)
kishore ch's Avatar
Member: 642004
Thanks Meter: 100
Onely flash set is ok like
The Following User Says Thank You to kishore ch For This Useful Post:
Old 05-26-2014, 11:48   #7 (permalink)
Member: 283153
Thanks Meter: 30
successfully unlock I9082
The Following User Says Thank You to jeewantha For This Useful Post:
Old 05-30-2014, 17:57   #8 (permalink)
Member: 1802623
Sonork: 100.1601666
Thanks Meter: 6
samsung i9082 unlock dune with SAMSUNG TOOL V17.5
Selected port: COM5 Z3X BOX Serial Port
Phone not found
Done with Samsung Tool v.17.5
Selected port: COM87 SAMSUNG Mobile USB Serial Port
Please, allow USB debugging on phone... OK
Model: GT-I9082
Phone version: I9082XXUBNA2
PDA version: I9082XXUBNA5
CSC version: I9082OJVBNA2
IMEI: 351778063922054
Phone S/N: RF1F31FA08R
Detected new type of security
Calculating... OK
Unlocking... OK
Unlock done
The Following User Says Thank You to ferdoush For This Useful Post:
Old 06-03-2014, 19:19   #9 (permalink)
Member: 2102288
Thanks Meter: 2
yes boss 100% working
The Following User Says Thank You to gsmkobir661 For This Useful Post:
Old 06-07-2014, 15:51   #10 (permalink)
Member: 928991
Thanks Meter: 20
Lot of thanks brother ,100% working fine.samsung grand i9082 version 4.2.2 done via z3x tool....keep it up
The Following User Says Thank You to kismathp For This Useful Post:
Old 06-21-2014, 07:12   #11 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 136
Selected port: COM11 SAMSUNG Mobile USB Serial Port
Model: GT-I9082
Phone version: I9082XXUBMI1
PDA version: I9082XXUBMK8
CSC version: I9082OJVBMJ1
IMEI: 351778062315268
Phone S/N: RF1F2012HFA
Unlocking... OK
Unlock done
Done with Samsung Tool v.17.3
after unlock still asking unlock code plzz help
Old 07-09-2014, 11:54   #12 (permalink)
Member: 1781519
instraction follow step by step, bt no result.
plz give me some link step by step.
Old 08-11-2014, 05:13   #13 (permalink)
Member: 1898671
Sonork: 100.1594422
Thanks Meter: 31
photo storage
The Following User Says Thank You to jumper77 For This Useful Post:
Old 08-11-2014, 07:01   #14 (permalink)
jewelmajj's Avatar
Member: 1553137
Sonork: 100.1652229
Thanks Meter: 56
use latest v17.9
use latest v17.9 .........................
Originally Posted by jumper77 View Post
photo storage
The Following 3 Users Say Thank You to jewelmajj For This Useful Post:
Old 09-08-2014, 15:30   #15 (permalink)
macts2012's Avatar
Member: 2241093
Sonork: 100.1663807
Thanks Meter: 84
Many many thanks brother.....I hope help this.......
Page generated in 0.22649 seconds with 9 queries
