07-10-2015, 01:19 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | G530H IMEI Certs Write Done Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G530H Selected port: COM9 Easy Jtag Control Port, Versión de Software : 21.7 Checking certificate file... Listo KEY ID: 0504 Esperando dispositivo ADB... Listo Leyendo información del teléfono ... Modelo: SM-G530H Versión de Android: 4.4.4 Código del Producto: Not Active Versión del telefono: G530HXCU1AOA2 Versión PDA: G530HXCU1AOA2 Versión CSC: G530HOJV1AOA1 CSC country code: UAE CSC sales code: XSG HW version: Teléfono S/N: 00000000000 Modem board: MSM8216 RF cal date: NONE IMEI: 35721306140XXX Initialization AT RIL... Listo Desviar MSL... Listo Checking for compatible phone and cert... Listo Phone KEY ID: 0504 Writing CERT... Listo Checking CERT status... Listo Writing Slave CERT... Listo Checking Slave CERT status... Listo Reiniciando teléfono ... Listo Hecho con Samsung Tool v.21.7 |
The Following User Says Thank You to Shensohau For This Useful Post: |
