01-20-2016, 02:34 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: in the darkness
Member: 1516808 Status: Offline Thanks Meter: 95 | Help to unlock t599n Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAOH1 PDA version: T599NUVAOH1 CSC version: T599NTMBAOH1 IMEI: 356433057879341 Phone S/N: R21DB6YW7QF Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM7 OK Bypass MSL... error Done with Samsung Tool v.17.9 Done with Samsung Tool v.17.9 |
01-20-2016, 02:39 | #2 (permalink) |
Member: 1516808 Status: Offline Thanks Meter: 95 | Selected model: T599N Selected port: COM5 RIM Virtual Serial Port v2 Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAOH1 PDA version: T599NUVAOH1 CSC version: T599NTMBAOH1 IMEI: 356433057879341 Phone S/N: R21DB6YW7QF Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM5 Port open fail COM5 Done with Samsung Tool v.17.9 Done with Samsung Tool v.17.9 |
01-20-2016, 22:07 | #4 (permalink) |
Member: 1516808 Status: Offline Thanks Meter: 95 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button. Operation: Unlock Selected model: SGH-T599N Software version: 20.4 Waiting ADB device... OK Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAOH1 PDA version: T599NUVAOH1 CSC version: T599NTMBAOH1 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone S/N: R21DB6YW7QF Modem board: DB8520H RF cal date: 2013.11.20 IMEI: 356433057879341 Checking Super user right... true Reading data from phone... OK Analysing SEC file... OK Bypass MSL... error (2) Done with Samsung Tool v.20.4 |
01-20-2016, 22:54 | #5 (permalink) |
Member: 1516808 Status: Offline Thanks Meter: 95 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button. Operation: Unlock Selected model: SGH-T599N Software version: 20.4 Waiting ADB device... OK Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAOH1 PDA version: T599NUVAOH1 CSC version: T599NTMBAOH1 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone S/N: R21F64DKVBF Modem board: DB8520H RF cal date: 2013.11.20 IMEI: 356433057879341 Checking Super user right... true Reading data from phone... OK Analysing SEC file... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.20.4 STILL ASKING FOR UNLOCK CODE. |
01-20-2016, 22:54 | #6 (permalink) |
Member: 1516808 Status: Offline Thanks Meter: 95 | Selected model: T599N Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAOH1 PDA version: T599NUVAOH1 CSC version: T599NTMBAOH1 IMEI: 356433057879341 Phone S/N: R21F64DKVBF Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM7 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Rebooting phone... OK Done with Samsung Tool v.17.6 Done with Samsung Tool v.17.6 STILL ASKING FOR UNLOCK CODE ALSO AND 00000000 DOES NOT WORK. |
01-03-2017, 07:39 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | PRO ACTIVATION doesn't help on that model! -------------------------------------------------- Operation: Unlock Selected model: SGH-T599N Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAOH1 PDA version: T599NUVAMD4 CSC version: T599NTMBAMD4 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: R21D69490HR Modem board: DB8520H RF cal date: 2013.06.27 IMEI: 356433051651845 Checking Super user right... true Reading data from phone... Ok Analyzing SEC file... Ok Bypass MSL... error (2) Done with Samsung Tool PRO v.27.7 |
01-04-2017, 03:30 | #10 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | This is what "tec9inc" suggests from the Z3X team forums: OK I figured it out here are the steps in order* 1. Make sure you are using Samsung tool 16.0 2. root phone using CydiaImpactor or use this file via Odin for permanent stock rooted**Dev-Host - T599N-Pre-rooted.zip - The Ultimate Free File Hosting / File Sharing Service (Metro PCSt599N) 3. Turn on USB Debugging 4. dial *#7284# UART - PDA and USB to PDA 5. Connect MicroUSB cable 6. Make sure correct Com Port is selected in tool, and Click Unlock in Tool 7. at Checking Com Port step in script switch to MicroUart Cable.... Done ========================== Selected model: T599N Selected port: COM67 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SGH-T599N Android version: 4.1.2 Product code: SGH2T599EAATMB Phone version: T599NUVAMD4 PDA version: T599NUVAMD4 CSC version: T599NTMBAMD4 IMEI: 356************ Phone S/N: R2*********** Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM67 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 ( 8 zeros) Done with Samsung Tool v.16.0 Done with Samsung Tool v.16.0 ========================== |
