02-07-2018, 14:44 | #16 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,708 | flash the entire combination then from stock firmware only flash sboot\cm\boot\system\recovery\modem..phone will goes to recovery just press reboot..when phone complete the setup just go to settings by swiping the notification screen down..u will see the settings icon press it and enable developer menu and enable oem... with best regards.. |
02-07-2018, 15:02 | #17 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | YOU CANT ERASE FRP WHILE COMBO IS ON..the point of flashing the combo is to enable adb...so when you flash stock back with home instead of csc adb is enabled so you can then bypass frp with stock rom installed 1. flash combo 2. flash stock rom back with home instead of csc 3. use z3x to bypass frp via adb |
The Following 2 Users Say Thank You to markhaines1985 For This Useful Post: |
02-07-2018, 18:16 | #18 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: France 72,77
Member: 521955 Status: Offline Thanks Meter: 261 | Quote:
I Flash combination Flash only sboot, cm, boot, system, recovery modem, from stock phone not go to recovery but stuck on logo. Thanks for idea.... | |
02-10-2018, 01:35 | #19 (permalink) |
Member: 2532914 Status: Offline Thanks Meter: 1,154 | let me say this again...you flash the entire stock rom after you flash the combo file....the only thing you do different is flash home file in csc slot. dont skip any files..flash the entire rom |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
02-12-2018, 18:19 | #20 (permalink) |
Member: 521955 Status: Offline Thanks Meter: 261 | Thnaks ; I try two time the full procedure but doesn't work. I flash entire stock rom with normal CSC (not the csc home) I flash combination I flash entire stock rom with Home csc Phone reboot but frp still on, and phone ask gmail. Any ideas please, I search always, thanks for all. |
02-12-2018, 21:28 | #22 (permalink) | |
Freak Poster Join Date: Jul 2016
Member: 2596108 Status: Offline Thanks Meter: 58 | Quote:
The Following User Says Thank You to wirelessinfinit For This Useful Post: |
02-13-2018, 02:27 | #23 (permalink) |
Member: 2532914 Status: Offline Thanks Meter: 1,154 | they dont listen. i told them 3 freaking times you cant wipe the frp while combo rom is on the phone..FOR THE LAST FREAKING TIME. YOU FLASH THE COMBO SO WHEN YOU FLASH FULL STOCK ROM BACK WITH HOME INSTEAD OF CSC YOU WILL THEN HAVE ADB ENABLED SO YOU THEN CAN BYPASS FRP. READ READ READ |
02-13-2018, 16:01 | #25 (permalink) | |
Freak Poster Join Date: Dec 2017
Member: 2792776 Status: Offline Sonork: 1577835 Thanks Meter: 82 | Quote:
in start its again gone to download mode not getting stable on ADB command | |
02-14-2018, 10:07 | #26 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | 100 % worked for me 1st download combination [up_vnROM.net]_COMBINATION_FA71_N950FXXU3ARA2_CL12771072_QB16471 415 flash with z3x reset frp selecting g935p then go on dialer or calc write *#0808# select last option DM + MODEM + ADB then go again setting and do full reset after it will reboot then take it again into download mode [up_vnROM.net]_N950FXXU3BRA2_N950FOXM2BRA1_XEF_FULL and flash with BL AP and CSC on BL just select sboot.bin on AP just select boot.im recovery.img & system.img on CSC (HOME) select only cache.img FLASH fone and u will c it will bypassed |
The Following 9 Users Say Thank You to Y2ksalman For This Useful Post: |
02-14-2018, 14:02 | #27 (permalink) | |
No Life Poster Join Date: Jan 2012
Member: 1713296 Status: Offline Thanks Meter: 67 | Quote:
02-14-2018, 16:10 | #28 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Combination https://drive.google.com/uc?id=1HdL2...xport=download Full Firmware https://drive.google.com/uc?id=1E68W...xport=download |
The Following 3 Users Say Thank You to Y2ksalman For This Useful Post: |
02-15-2018, 01:52 | #29 (permalink) | |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | Quote:
Any solution for OEM UNLOCK missing? This is due to the new RMM lock on some later model phones including this one. | |
The Following User Says Thank You to gsm_service4u For This Useful Post: |
