07-28-2014, 22:11 | #33 (permalink) |
Major Poster Join Date: Aug 2006 Location: Serbia
Member: 326617 Status: Offline Thanks Meter: 8 | How to fix network, full process Hi to all, I had a same problem with T999 and i747M no network after unlock. So here is the full procedure what I have done: 1. Download exact recovery file from TWRP for your device: TeamWin and flash it with Odin as PDA Please double check the recovery file or you can brick your device!!! 2. Download both zip files Super SU SuperSU Download and KNOX Removal SAMSUNGNIZER_KNOX_REMOVAL - 4shared from links and put it to your external SD Card, put the card back to phone. 3. Reboot to recovery (Vol+ and Home) 4. Install both .zip files. Select Install, chose storage (up in the middle) select SD Card. Install one then the other Super SU and KNOX Removal, and reboot the phone to normal mode. ROOT DONE! (KNOX Removal is important for Android 4.3+ because Super SU will display the error and wan't start!) 5. Unlock with Samsung Tool v17.8 by typing *#0808# on the phone and select DM+MODEM+ADB Click Reboot. Select SAMSUNG Mobile USB Serial Port on PORT Drop down menu (select New Security, select Skip backup/restore NVM) Click Unlock... 6. After "Unlock Done!" wait for the phone to power on and write the Network FIX from post#1 provided by Z3X as Full NVM Network FIX 7. Turn OFF the phone, insert SIM Card, Power ON and enjoy! My both phones Samsung S3 T999 from T-Mobile and i747M From Canada work like a charm! TNX Z3X DISCLAIMER : I am not responsible for bricked devices, dead SD cards or whatever happens to your phone. You are expected to know what you are doing when attempting to flash your phone. |
The Following User Says Thank You to DarkoGSM For This Useful Post: |
07-31-2014, 15:14 | #35 (permalink) |
No Life Poster Join Date: Dec 2001 Location: 127.0.0.0.1
Member: 8133 Status: Offline Thanks Meter: 72 | @ blang. I have a different but related issue. Basically after imei fix i get signal on i9505, however, as soon as the phone auto locks, signal drops altogether, and only comes back when lock is turned off. This is no good for when customer has phone in pocket and is out and about... I have tried to write that nvm above, twice. Both wrote successfully, but problem still occurs. So far i have tried everything inc EFS and NVM and still no success. Any help?? |
08-01-2014, 21:45 | #36 (permalink) |
No Life Poster Join Date: May 2010 Location: Argentina
Member: 1314806 Status: Offline Sonork: 100.1000 Thanks Meter: 80 | Selected model: I747M Selected port: COM76 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Reading IMEI... OK IMEI: 353323050755551 Build: M8960A-AAAANAZM-1.0.443139 Writing NVM... OK Done with Samsung Tool v.17.9 full signal. tnx team |
08-03-2014, 05:01 | #44 (permalink) |
Freak Poster Join Date: May 2014
Member: 2186335 Status: Offline Thanks Meter: 44 | Open eyes read first post pleas http://forum.gsmhosting.com/vbb/f453.../#post10458138 |
08-03-2014, 09:03 | #45 (permalink) |
Freak Poster Join Date: Aug 2004
Member: 76614 Status: Offline Thanks Meter: 29 | Samsung I747 Android 4.3 USA at&t Hi, I think the problem is fixed 50%. Samsung I747 Android 4.3 Problem 1: After the Unlock phone will take 10-15 minutes to pickup signal. Problem 2: After the unlock, you will only get edge. This solution fixes the problem 2. But this solution does not address problem 1 listed above. Here is the log Selected model: I747 Selected port: COM130 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Reading IMEI... OK IMEI: 35153706004xxxx Build: M8960A-AAAANAZM-1.0.443089 Writing NVM... OK Done with Samsung Tool v.17.9 |
