08-14-2014, 22:34 | #61 (permalink) |
Freak Poster Join Date: Aug 2005 Location: <<<...sPaCe...>>>
Member: 171153 Status: Offline Thanks Meter: 30 | Cannot Fix....After Network Repair - I Get Unkown BB IMEI SERIAL# 4d0026c8572f6053 Need To Reflash To Get Imei To 004xxxx Then Go Through Entire Process Of Repair Imei And Serial # Repair. To Get Back Everything As It Should. What To Do ??? Code: Selected model: I9500 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 4.3 Product code: Not Active Phone version: I9500XXUEMJ8 PDA version: I9500XXUEMJ8 CSC version: I9500OJVEMJ8 IMEI: 35891805162xxxx Phone S/N: RF1D90H8BKJ Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Repair done |
08-19-2014, 17:50 | #67 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | To fix 4GLTE networks for I747/T999 just use QPST program. Super easy to use QPST v2.7.378.zip: Dev-Host - QPST v2.7.378.zip - The Ultimate Free File Hosting / File Sharing Service Both of these NV Data backup files do the same thing. They just come from different sources. NV Data backup from T999L: T99LNV NV Data backup from I747 using Eng Modem and CSC: I747NV After using these files you will have to restore your IMEI as well using EFS professional or another IMEI repair tool such as Z3X Give a thanks if this helped! |
08-19-2014, 21:15 | #68 (permalink) |
Insane Poster Join Date: Sep 2008
Member: 857102 Status: Offline Thanks Meter: 6 | need to unlock t889 4.3 locked to u.s.a t mobile .i try to unlock with z3x box cant excess denied message comes. i think root problem .cant root the phone. plz tell me how to unlock this phone |
08-20-2014, 02:18 | #69 (permalink) |
Member: 857102 Status: Offline Thanks Meter: 6 | Re: t889 unlock 4.3 unlock problem -------------------------------------------------------------------------------- here is the logs Selected model: T889 Selected port: COM139 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179709 Done with Samsung Tool v.18.0 Selected model: T889 Selected port: COM139 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179709 Reading security... error access denied Done with Samsung Tool v.18.0 WHEN I PRESS NEW SECUIRTY AND TRY TO UNLOCK IT THIS IS WHAT IT SAYS Selected model: T889 Selected port: COM139 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.18.0 Done with Samsung Tool v.18.0 IN THE PHONE I CAN NOT ROOT SUPERUS IT SAYS ITS STOPPED. MESSAGES BLICKS KNOXS IS TRYING TO BLOCK THE FILE ETC |
08-21-2014, 11:54 | #72 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | not fixed on i9505 Selected model: I9505 Selected port: COM60 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Reading IMEI... OK IMEI: 35744105 Build: M9615A-CEFWTAZM-4.0.17167 Writing NVM... OK Done with Samsung Tool v.18.0 |
08-21-2014, 15:40 | #73 (permalink) | |
Freak Poster Join Date: Oct 2012 Location: Puerto Rico
Member: 1820439 Status: Offline Thanks Meter: 154 | Quote:
08-21-2014, 19:58 | #74 (permalink) |
Member: 857102 Status: Offline Thanks Meter: 6 | i try using vroot and kingoroot but cant root .i didnt try with towel root the phone is been return to customer. but have you tried and got sucess on the version build i show .i already did enable usb dedduging mode but still cant connect with the rooting by the 2 tools i mention. plz reply |
08-21-2014, 21:05 | #75 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | i have an h3g ita sim that works only follow this: searching network the first time h3g newtwork is "hidden" , so i register sim to roaming network search network again , h3g network appears , i register sim to him (hdspa/3g) with full signal |
