Old 11-20-2013, 12:15   #1 (permalink)
Member: 2028500
Start with Z3x box
I just receive my Z3x Box. I have much problem to use it.
When I run Shell and I go to 'Settings and Hardware Tools' Tab and I click on 'run Hardware wizard', a dialog box (card and Account wizard) appear.
I don't know what is card. I did not receive card in my z3x package
I have install Z3x in device manager (COM4 posrt)
Please help
Thank you
Old 11-20-2013, 16:16   #2 (permalink)
krisu0007's Avatar
Member: 1670851
Thanks Meter: 267
Please help
Thank you
Card is inside box. You must install both drivers-for box and card..then check in device manager if its installed properly-its not shown any unknown device, or device with exclamation mark (!)
The Following User Says Thank You to krisu0007 For This Useful Post:
Old 11-20-2013, 17:15   #3 (permalink)
Member: 2028500
I have installes drivers for box and card but :
In device manager, I can see Z3x Box serial port (COM4) under Ports (COM and LPT). under "USB Bus Contyroler", I can see 'Z3x USB Serial converter'. Nothing else with exclamation mark. Nothing about card.
Thank
Old 11-21-2013, 11:37   #4 (permalink)
Member: 2028500
Hi
Still say : 'card not found'
Thank
Old 11-26-2013, 15:24   #5 (permalink)
Member: 2028500
Hi
Finally I have configure my box and it is recognize by my computer. I have tried to repair my IMEI but I have some problems. It seems as my UART cable have problem because when Samsung Tool ask me to connect my phone with UART cable, I do so. But at the end, I have the message that : "No answer from phone". below is the report. My S3 is connected via COM4.
Selected model: I9300
Selected port: COM4 Z3X BOX Serial Port
Selected port speed: 115200
Searching ADB device... OK
Reading phone info...
Model: GT-I9300
Android version: 4.1.2
Product code: Not Active
Phone version: I9300XXEMB5
PDA version: I9300XXEMB5
CSC version: I9300OXAEMB5
IMEI: 004999010640000
Phone S/N: 00000000000
Checking Super user right... true
Reading data from phone... OK
Repairing network settings... OK
Writing data to phone... OK
Rebooting phone... OK
Now connect phone to UART cable
Checking phone at COM4
Done with Samsung Tool v.16.1
After connecting the phone to UART cable, it still chearching it from COM4 port. And after, the message is : No answer from phone.
Is there any command to test a UART cable ?
Thank
Old 11-29-2013, 14:39   #6 (permalink)
Member: 2028500
Hi
Thank you for your reply. I have downloaded the 16.2 version of Samsung Tool. The message error have changed. Now I have:
Searching Samsung modem... detected COM3
Software version: I9300XXEMB5/I9300XXEMB5/I9300OXAEMB5
Product code: XXXXXXXXXXXXXX
Done with Samsung Tool v.16.2
Model: GT-I9300
Reading nv data... OK
Reading modem... OK
Reading kernel... OK
Exception: Access violation at address 00409E37 in module 'SamsungTool.exe'. Read of address 7FDA0000
Access violation error. What to do now ?
Thank you very much
Page generated in 0.16400 seconds with 8 queries
