08-19-2017, 19:56 | #1 (permalink) | |
Insane Poster Join Date: Dec 2014
Member: 2304127 Status: Offline Thanks Meter: 8 | SM-G930V cannot unlock by Read code Please help me About G930V cannot unlock by readed code. after enter code its say code incorrect on NON-Verizon sim card inserted. Help me pls. here is my log Quote:
08-20-2017, 12:29 | #5 (permalink) |
Member: 2304127 Status: Offline Thanks Meter: 8 | Brother in combination is factory binary. If Combination network ok then all version ok. And this mobile is updated at bootloader U4. In U4 no 6.0.1 available. Thanks. I am waiting for Team reply. |
08-21-2017, 04:30 | #7 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Dominican Republic
Member: 482218 Status: Offline Thanks Meter: 119 | test phone before trying to unlock. most non-prepay verizon phones are factory unlocked. edit: the non verizon sim card will always be shown. verizon phones have that. |
09-12-2017, 23:51 | #9 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAÑA
Member: 808967 Status: Offline Thanks Meter: 155 | ask this code read me but do not unlock help team I make the code that I generate is not UNLOCK INSTRUCCIONES: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes via Server Selected model: SM-G930V Selected port: COM9 RIM Virtual Serial Port v2 Software version: 29.2 Checking Login and Password... Listo Ballance: 40 crd. Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-G930V Android version: 6.0.1 Código del Producto: SM-G930TZKAVZW Versión del telefono: G930AUCU4AQE1 PDA version: G930VVRU4API3 CSC version: G930VVZW4API3 Código de país CSC: USA Código de Venta CSC: VZW HW version: REV0.6 Phone SN: R58H30SLRSL Chip name: MSM8996 Módem: MSM8996 Security patch: 2016-10-01 RF cal date: 2016.03.05 IMEI: Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM11 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 25020202 NET lock: 13046963 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.29.2 |
