07-10-2015, 06:15 | #1 (permalink) |
Insane Poster Join Date: Dec 2013 Location: Santa Ana, CA
Member: 2082382 Status: Offline Thanks Meter: 18 | Note 4 N910V cannot write cert! Please help!!! From what i know, N910V doesn't need to wipe efs and reset msl to write cert. Anybody has idea to help me fix this problem please? |
07-10-2015, 07:20 | #3 (permalink) |
Insane Poster Join Date: Mar 2014 Location: LOUISIANA Age: 42
Member: 2140825 Status: Offline Thanks Meter: 5 | solution if phone has been repaired before, somtimes alters msl, go into cdma was or dfs , connect to phone serial port send 16 and spc, disconnect port run imei repair , then match meid and imei, and if on 5.01 you must do efs wipe in menu firs 4.4.4 just repair like normal |
The Following User Says Thank You to smsprepaids For This Useful Post: |
07-10-2015, 18:57 | #4 (permalink) |
Member: 2082382 Status: Offline Thanks Meter: 18 | I use DFS to send the 16digit password and spc. Then use the button "open/close port" to disconnect it from DFS. Then run samsung pro tool to write cert but it still gives an "error(2)...First resetting MSL". Did i do something wrong? |
07-12-2015, 04:28 | #6 (permalink) |
Member: 2140825 Status: Offline Thanks Meter: 5 | msl you can alaways do it the long way and wipe efs in service menu which should default the msl, just make sure you have a qcn back up thats been pulled for a 16 digit password opened device. the write back , write qcn match meid. Usually the other method works. but things happen |
