01-29-2018, 13:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2640240 Status: Offline Thanks Meter: 150 | Note 8 T Mobile N950u Unlock Done With Z3x Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-N950U Selected port: COM122 SAMSUNG Mobile USB Serial Port Software version: 30.5 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZKATMB Phone version: N950USQU2BQLA PDA version: N950USQU2BQLA CSC version: N950UOYN2BQLA CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J84GMYMP Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-12-01 RF cal date: 2017.08.31 IMEI: 358????????????? Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM138 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Thanks For Kamal |
