Old 03-30-2021, 12:52   #1 (permalink)
Member: 683086
Thanks Meter: 15
unlock a715f [Answered]
hi
need help to unlock this phone
UNLOCK INSTRUCTIONS:
To read security codes using sever:
Knox warranty does not matter.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-A715F
Software version: 42.7
Checking Login and Password... OK
Ballance: 20 crd.
You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-A715F
Android version: 11
PDA version: A715FXXU3BUB5
CSC version: A715FODX3BUB5
Phone version: A715FXXU3BUB4
Product code: SM2A715FZBUMBM
CSC country code: MACEDONIA
CSC sales code: MBM
Carrier ID: MBM
Phone SN: R58NC4BCHXP
IMEI: 359969539802234
HW version: MP 0.300
RF cal date: 2020.12.25
Chip name: SM7150
Modem board: SM7150
Security patch: 2021-02-01
Boot Warranty bit: 0
SIM State: ABSENT,NETWORK_LOCKED
Searching Samsung diag port... not found
Please enable diag using *#0808# or check USB drivers.
Done with Samsung Tool PRO v.42.7
Old 03-30-2021, 13:31   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,062
Hello. Tap *#0808# and choose dm acm adb. Then repeat operation.
Old 03-30-2021, 13:39   #3 (permalink)
Member: 683086
Thanks Meter: 15
i have alrady do it ....
File Type: jpg image0.jpg (157 Bytes, 116 views)
Old 03-30-2021, 13:40   #4 (permalink)
Member: 683086
Thanks Meter: 15
i think problem with driver
File Type: jpg image0.jpg (157 Bytes, 115 views)
Old 03-30-2021, 14:14   #5 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,062
I cant see images that you attached.
Page generated in 0.18154 seconds with 9 queries
