10-25-2016, 13:00 | #46 (permalink) | |
Insane Poster Join Date: Mar 2014 Location: Turkey
Member: 2148197 Status: Offline Thanks Meter: 80 | Quote:
Yeni bootloader olmuyor bu arada birbirimizi kandırmayalım olur mu kaderşim | |
11-01-2016, 20:19 | #48 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2589731 Status: Offline Thanks Meter: 2 | pasaport kaydı yapacagım çöktü imei islemi yapmamıstım zaten yedeklerını almıstım suan ımeı aynı tenten can |
The Following User Says Thank You to ertugrulbulut19 For This Useful Post: |
11-17-2016, 21:28 | #54 (permalink) |
Junior Member Join Date: Jan 2008
Member: 676141 Status: Offline Thanks Meter: 0 | hi there thank you for the post I have managed to make my note 5 sm-n920c work but there is a problem I am unable to make calls it says not registered although the data works and its registered on network very well internet works everything is fine accept for making calls any idea please? I had a different firmware from Cambodia and its rooted I only used the one click root and the 2 files as per your instruction please help me to be able to make calls thank you *** bless |
11-17-2016, 21:34 | #55 (permalink) | |
Junior Member Join Date: Jul 2013
Member: 1980596 Status: Offline Thanks Meter: 0 | Quote:
12-01-2016, 11:06 | #58 (permalink) | |
Insane Poster Join Date: Apr 2006 Location: Ankara
Member: 266278 Status: Offline Thanks Meter: 12 | Quote:
Thanks man for sharing your experience. It worked for me. Hayirly isler abicim. | |
The Following User Says Thank You to arsl For This Useful Post: |
01-10-2017, 13:31 | #59 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 409 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-N920C Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-N920C Android version: 6.0.1 Product code: SM-N920CZDAEGY Phone version: N920CXXU3BPIC PDA version: N920CXXU3BPJ5 CSC version: N920COJV3BPJ3 CSC country code: Egypt CSC sales code: EGY HW version: MP 0.700 Phone SN: RF8G80RNE4E Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20150810 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON333 HWID: 88 6E 90 CE B6 05 00 00 00 00 00 00 00 00 00 00 Calculating... Ok Initialization AT RIL... AT RIL stopped, restarting... Ok Checking for compatible phone and cert Phone KEY ID: 0448 Checking certificate file... Ok KEY ID: 0448 Crypting CERT 1... Ok Writing NV data... Ok Rebooting phone... Ok Write CERT done Done with Samsung Tool PRO v.27.7 N920C CERT - Download - 4shared - Le Vent Pro ouedraogo |
The Following User Says Thank You to Freeboy08 For This Useful Post: |
