Phone Freeze C3300k and not unlock with 2G_tools_3.5.0004 For me it's not working fine, i have just try with usb or uart cable, but for log the unlock is ok, really the phone is freeze. If i Check the locks with code *#7465625# , the phone result locked again! How i can resolve? thanks This is my eprom phone: MEGAUPLOAD - The leading online storage and file delivery service |
c3300k unlock done by z3x. c3300k unlock done by z3x .thenks z3x teem for good support ( use 3300k RJ45 cable by z3x) http://www.gsm-support.net/www/image...-nspro_mid.jpg http://img18.imageshack.us/img18/2679/z3xc.jpg BR ..::KASHIF::. Gsm Forum> |
The same log for my phone, but the phone is not unlock! For me the first problem is freeze status. |
I have the same problem with C3300K, if the phone is freezed, z3x can't unlock :( Can't read codes from the phone (com or usb) so i solve the problem with HWK. If you have HWK read the codes on com port, and it will be done :) |
Yes i have HWK, but which cable you use? With micro usb, the boz don't recognize the phone. BR |
I use C3300K RJ45 cable for HWK not for for Z3X, only the box pinouts are differents. |
I don't have this cable but only for z3x!! |
You can modify yourself the cable, just change the RJ45 to work with HWK. Clone on other working cable RJ45 pinouts for HWK. |
try to read info(codes) the first code is reset code. insert sim power on phone insert master code and after that u will be asked 4 network code |
When i try to read info codes the result is: Selected model: C3300K Selected com port: COM5 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone IMEI -> ************** Phone SW -> C3300KBBJG7 Langpack-> Tmn, Portugal Phone HW -> MP 0.802 Phone BT ADDR -> 101D-C0-DAE9FA Phone WI-FI ADDR -> [NET LOCK]: [SIM LOCK]: [PHONE LOCK]: [SP LOCK]: Read Info - ok Elapsed time: 25 second, sw ver: 3.5.0004 If i try with the code #7465625*638*00000000# the phone respond with "wrong password" message, and it's in freeze mode. Quote:
The same to me. Phone freezed can not be solved |
Mr blang can you help us? BR |
It's really working for phone freeze? Quote:
thanx a lot |
