11-10-2014, 20:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Nr Glasgow Age: 52
Member: 579376 Status: Offline Sonork: 100.1618321 Thanks Meter: 11 | Samsung S5 SM-G900F Unlock Procedure request help just want confirmation of correct / proper procedure to unlock handset as its customers and dont want to damage handset. Can anyone give me instruction of tried and tested successfull way to unlock said handset. |
11-10-2014, 20:21 | #2 (permalink) |
Freak Poster Join Date: Aug 2012 Location: england
Member: 1798097 Status: Offline Thanks Meter: 86 | I would prefer if you unlock your customer's with IMEI unlock request. If you do the software version of unlocking then it will change your imei and also mess with your signals. And later on in time the phone will get blocked. The best idea is to just unlock through original factory procedure. Thanks Sent from my iPhone using Tapatalk |
The Following User Says Thank You to aryan cartio For This Useful Post: |
11-10-2014, 20:32 | #4 (permalink) |
Member: 1798097 Status: Offline Thanks Meter: 86 | Z3x has a solution to unlock your phone but still you will have to use some other phone's certificate file which still changes your imei number. And if 10 people use the same certificate "same imei" then it will be blacklisted one day and that will be soon. Sent from my iPhone using Tapatalk |
