pls help flash SM-G925t i have samsung sm-g925t i cant flash it,any time try to flash it stop at <OSM> Leave CS.. <ID:0/004> Odin v.3 engine (ID:4).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> sboot.bin <ID:0/004> NAND Write Start!! FLASH FILE 6.0.1 AND WHEN I TRY TO FLASH WITH HOME FILE TOO,THE SAME ERROR PLS HELP:mad::mad::rolleyes: |
If its on the newer build you will not be able to downgrade it. What 6.0.1 build is it currently on, and which 6.0.1 build are you trying to flash? |
its was on the home files G925TUVU3EPD1_G25TTMB3EPD1_6.0.1_USA_HOME.ZIP that was what i used.......pls help me |
its was running on 5.1.1 |
ok man i will try and let u know and thanks by the way |
