02-05-2011, 13:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: deveselu
Member: 543935 Status: Offline Thanks Meter: 59 | i need solution for t310 with rj45 gs 102, with ¨¨test point work well¨¨ i tried with the phone turned off, of... with battery, without baterry, with 2x1 cable usb+rj45,,, but still not work, the soft not connectigt with the phone, onli blinking the leds of the box... BUT WITH RX AND TX CONNECTED IN THE MOTHERBOARD THE SOFT CONNECT SUCCESFULY AN READ OK THE CODES... I NEED SOLUTION FOR CABLE PLS Z3X TEAM PLS BEST REGARDS ADELIN OK WIT ¨¨¨TEST POINT BUT NOT IN RJ45+USB OR WITHOUT USB¨¨ Welcome to LG Infineon SGOLD3 TOOL v2x by NoNameŽ Models count: 88 Current OS : Windows Seven BUILD:6/7600 Welcome to Sgold3 Module!! Count supported models - 88 ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8810 Module 1.1 started. SW: Ver 2.3.0.1 Connecting to T310 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... BOOT Failed ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8810 Module 1.1 started. SW: Ver 2.3.0.1 Connecting to T310 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... BOOT Failed ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8810 Module 1.1 started. SW: Ver 2.3.0.1 Connecting to T310 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8810) prebooting... Release power button. Booting... Waiting for loader answer... Reading info... Flash ID: 0xEC00 Force boot mode on! Finished in 36 seconds ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8810 Module 1.1 started. SW: Ver 2.3.0.1 Connecting to T310 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8810) prebooting... Release power button. Booting... Waiting for loader answer... Reading info... Flash ID: 0xEC00 BOOT Stage Finished , sending authority... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\T310_autobackup_050220 11_012351.eep Analising EEPROM... Phone IMEI:3538110473378710 Unlock codes: NCK[0]: 0000000000000000 (UNLOCKED) NCK[1]: 0000000000000000 (UNLOCKED) NCK[2]: 0000000000000000 (UNLOCKED) NCK[3]: 2840901079904097 (UNLOCKED) NCK[4]: 2840901079904097 (LOCKED) NCK[5]: 2840901079904097 (LOCKED) NCK[6]: 2840901079904097 (LOCKED) NCK[7]: 2840901079904097 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 26 seconds |
02-14-2011, 14:51 | #4 (permalink) |
No Life Poster Join Date: Jun 2002 Location: City
Member: 12663 Status: Offline Thanks Meter: 78 | Yes, tested, without battery and using USB cable Loading module , please wait... PMB8810 Module 1.1 started. SW: Ver 2.3.0.1 Please connect phone , it must be powered off Port Handle:000001B4 Phone found! (MCU:PMB8810) prebooting... Sending Preloader... Sending Loader... Waiting for loader answer... Reading info... Flash ID: 0xEC00 BOOT Stage Finished , sending authority... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\T310_autobackup_140220 11_145009.eep Analising EEPROM... Phone IMEI:3558270419XXXXXX Unlock codes: NCK[0]: 0000000000000000 (UNLOCKED) NCK[1]: 0000000000000000 (UNLOCKED) NCK[2]: 0000000000000000 (UNLOCKED) NCK[3]: 2886138103255467 (UNLOCKED) NCK[4]: 2886138103255467 (LOCKED) NCK[5]: 2886138103255467 (LOCKED) NCK[6]: 2886138103255467 (LOCKED) NCK[7]: 2886138103255467 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 2 seconds |
04-26-2011, 13:43 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | i have the same problem with GS102 cable RJ45 can't conect. usb without battery only power on how to do test point? i need it may be the better solution now. |
04-26-2011, 20:38 | #7 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | i think it is the same usb mini cable for blackberry i always use! anyways no success with mini usb or micro uart cable GS102 i alway use for other operation. i need TP on motherboard where i can soldered wire directly for unlock operation please! |
04-28-2011, 23:26 | #10 (permalink) | |
Member: 118601 Status: Offline Thanks Meter: 200 | i Finaly done mine follow this link:http: //forum.gsmhosting.com/vbb/6814530-post21.html te real problem about driver installation. use the one on that link and you can easily unlock by sub in fews second. Quote:
06-06-2011, 14:58 | #11 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Ghana-Accra
Member: 311615 Status: Offline Sonork: 100.1591575 Thanks Meter: 72 | I think the ordinary Lg t310 does not support usb unlock but when u choose the t310GO as the model u will be tru and unlock it easy...! |
08-08-2011, 13:40 | #13 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Moroni Comoros Age: 49
Member: 127093 Status: Offline Thanks Meter: 22 | unlock lg t310 by micro usb without batterie(driver usb flash from ://forum.gsmhosting.com/vbb/6814530-post21.htm Loading module , please wait... PMB8810 Module 1.1 started. SW: Ver 3.2.0.0 Please connect phone , it must be powered off Port Handle:00000178 Phone found! (MCU:PMB8810) prebooting... Sending Preloader... Sending Loader... Waiting for loader answer... Reading info... Flash ID: 0x89B1 Force boot mode on! Finished in 6 seconds Reading ... Detailed Phone Information: Phone Model: T310 Phone Manufacturer: LGE Inc. Phone Version: Unavaiable for this platform. Phone IMEI : 353xxxxxxxxxxxx Phone BT Adress : 5C:173:4E:69:CE Detailed Codes Information: Phone NCK Code : 3479-8329-4399-7631 Phone NS Code : 5942-4293-1333-6605 Phone SP Code : 9090-7206-7250-1677 Phone CP Code : 4538-7085-6319-0361 Phone SIM Code : 0469-3052-9400-6309 SimLocks Disabled SP Lock Disabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: Unavaiable for this platform. For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# or 2945#*XXX# where XXX - model digits to enter unlock menu 3. Enter one of this code(s): Finished in 2 seconds |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
