02-11-2016, 10:35 | #15586 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G925F Software version: 24.2 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 5.1.1 Product code: SM-G925FZDEVOD Phone version: G925FXXU3QOKN PDA version: G925FXXU3QOKN CSC version: G925FVFG3QOKN CSC country code: UK CSC sales code: VOD HW version: MP 0.70V Phone S/N: R58G71KRNZK Modem board: SHANNON333 RF cal date: 20150727 IMEI: Checking Super user right... true Initialization AT RIL... OK Check version... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 20617380 NET lock: 84131808 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.24.2 |
02-11-2016, 12:04 | #15587 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Samsung l600 unlock Code: UNLOCK INSTRUCTIONS: Direct Unlock: 1. Power on the phone. 2. Type ##3424# and select 'DM + MDM + ADB'. 3. Select 'Qualcomm USB Settings' and choose 'DM/DUN over HSIC'. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Unlock' button. Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. Operation: Unlock SPRNT Selected model: SPH-L600 Selected port: Software version: 24.0 Waiting ADB device... OK Reading phone info... Model: SPH-L600 Android version: 4.4.2 Product code: Not Active Phone version: L600VPUBOH1 PDA version: L600VPUBOH1 CSC version: L600SPTBOH1 CSC country code: USA CSC sales code: SPR HW version: L600.04 Phone S/N: 00000000000 Modem board: MSM8930AB RF cal date: 2014.04.16 IMEI: 990004486659653 Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.0 |
02-11-2016, 17:21 | #15588 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-I9023 Software version: 24.2 File analysis... OK Total file size: 0x0CF1DF90 (207 Mb) Searching USB Flash Interface... detected COM92 Setup connection... OK Reading PIT from phone... OK Sending bootloader.img... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Flashing done (time - 00:01:16) Done with Samsung Tool PRO v.24.2 |
02-11-2016, 18:08 | #15589 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected model: T399 Selected port: COM93 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: SGH-T399N Android version: 4.4.2 Product code: Unknown Phone version: T399NUVUANH1 PDA version: T399NUVUANH1 CSC version: T399NTMBANH1 IMEI: 350695200123951 Phone S/N: RV8F90DH0RY Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Repair done |
02-12-2016, 05:16 | #15590 (permalink) |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | Operation: Write CERT Selected model: SM-G900V Selected port: COM25 USB Serial Port Software version: 24.2 Checking certificate file... OK KEY ID: 0478 Waiting ADB device... OK Reading phone info... Model: SM-G900V Android version: 5.0 Product code: Not Active Phone version: G900VVRU2BOK3 PDA version: G900VVRU2BOK3 CSC version: G900VVZW2BOK3 CSC country code: USA CSC sales code: VZW HW version: G900V.05 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.07.30 IMEI: Initialization AT RIL... OK Bypass SPC... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK |
02-12-2016, 05:50 | #15591 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | LG 2-3G Tool v8.9 supported models: 1116 Check Android Lollipop... Stage #1 OK Mode: Normal Model: WX_PROJE Build version: Aug 17 201521:00:30Feb 12 201405:00:00WX_PROJE SW Version: M8610B-AAAANAZM-1.0.6038 IMEI: 01403800568448-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default SPC: 000000 Elapsed: 0 secs. --> (v8.9) Check Android Lollipop... Stage #1 OK Mode: Normal Model: WX_PROJE Build version: Aug 17 201521:00:30Feb 12 201405:00:00WX_PROJE SW Version: M8610B-AAAANAZM-1.0.6038 IMEI: 01403800568448-9 BlueTooth Address: 00:00:00:00:00:06 Phone Code: default SPC: 000000 Elapsed: 0 secs. --> (v8.9) Direct unlock Working with security zone Checking phone at COM23 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM4 Reboot phone Done Elapsed: 49 secs. --> (v8.9) |
The Following User Says Thank You to ghacks For This Useful Post: |
02-12-2016, 07:54 | #15592 (permalink) |
Junior Member Join Date: Jul 2015 Location: United States
Member: 2419703 Status: Offline Sonork: jawad Thanks Meter: 0 | imei repair N928T Operation: Write CERT Selected model: SM-G928T Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 5.1.1 Product code: SM2G928TZDATMB Phone version: G928TUVS2COKC PDA version: G928TUVS2COKC CSC version: G928TTMB2COKC CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: 20151125 IMEI: Checking Super user right... true Initialization AT RIL... OK Checking certificate file... OK KEY ID: 0784 Check version... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done |
02-12-2016, 10:39 | #15593 (permalink) |
Freak Poster Join Date: Aug 2014 Location: UK
Member: 2240742 Status: Offline Thanks Meter: 76 | Operation: Unlock Selected model: GT-I8190N Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: GT-I8190N Android version: 4.1.2 Product code: GT-I8190RWNBTU Phone version: I8190NXXAMJ2 PDA version: I8190NXXAMJ2 CSC version: I8190NBTUAMJ1 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.700 Phone S/N: RF1D9803xxx Modem board: DB8520H RF cal date: 2013.10.02 IMEI: 3560360547xxxxx Checking Super user right... true Reading data from phone... OK Analysing SEC file... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.2 Thanx z3x |
02-12-2016, 10:47 | #15594 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | b350e no network done Operation: Patch Certificate Selected model: SM-B350E Selected port: Software version: 24.2 Waiting phone... detected COM18 Sending FDL... OK Reconnecting phone... OK Sending FDL2... OK Reading data from phone ... OK Writing data to phone... OK Patching CERT check... done Done with Samsung Tool PRO v.24.2 |
02-12-2016, 10:55 | #15595 (permalink) |
Member: 2240742 Status: Offline Thanks Meter: 76 | Operation: Unlock Selected model: SM-J100H Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: SM-J100H Android version: 4.4.4 Product code: SM-J100HZKATSC Phone version: J100HXCU0AOG1 PDA version: J100HXCU0AOG1 CSC version: J100HOXX0AOG1 CSC country code: UK CSC sales code: TSC HW version: MP 0.201 Phone S/N: R51G71Zxxxx Modem board: sc7727s RF cal date: 20150717 IMEI: 3528300734xxxxx Checking Super user right... true Running zTool, please wait... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.2 |
02-12-2016, 13:43 | #15596 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | GT-I9300 IMEI Repair Done By Write CERT Code: Checking certificate file... OK KEY ID: 0455 Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: GT-I9300RWDNZC Phone version: I9300XXUGNB1 PDA version: I9300XXUGOA2 CSC version: I9300NZCGOA1 CSC country code: New Zealand CSC sales code: NZC HW version: MP 1.400 Phone S/N: RV1D10P8V3D Modem board: RF cal date: 2013.1.8 IMEI: 357868678575472 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.24.2
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
02-12-2016, 13:44 | #15597 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | GT-I9500 IMEI Repair By Write CERT Code: Checking certificate file... OK KEY ID: 0833 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9500 Android version: 4.3 Product code: Not Active Phone version: I9500XXUEMJ8 PDA version: I9500XXUEMJ8 CSC version: I9500OJVEMJ8 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: REV__ Phone S/N: RF1D455LD9H Modem board: XMM6360 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.24.2
02-12-2016, 16:15 | #15598 (permalink) |
Member: 2240742 Status: Offline Thanks Meter: 76 | Operation: Unlock Selected model: GT-I8190N Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: GT-I8190N Android version: 4.1.2 Product code: GT-I8190RWNSFR Phone version: I8190NXXAMG3 PDA version: I8190NXXAMG3 CSC version: I8190NVFGAMF3 CSC country code: France CSC sales code: SFR HW version: MP 0.700 Phone S/N: RF1D4519xxx Modem board: DB8520H RF cal date: 2013.04.21 IMEI: 356036050xxxxxxx Checking Super user right... true Reading data from phone... OK Analysing SEC file... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.2 |
02-12-2016, 17:22 | #15599 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Write CERT Selected model: SM-N915A Selected port: COM14 SAMSUNG Mobile USB Serial Port Software version: 24.2 Checking certificate file... OK KEY ID: 0208 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-N915A Android version: 5.1.1 Product code: SM2N915AZKEATT Phone version: N915AUCU2COI2 PDA version: N915AUCU2COI2 CSC version: N915AATT2COI2 CSC country code: USA CSC sales code: ATT HW version: REV0.1 Phone S/N: Modem board: MDM9225M RF cal date: 2015.08.18 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0208 Writing CERT... OK Checking CERT status... OK Done with Samsung Tool PRO v.24.2 Operation: Unlock Selected model: SM-N915A Selected port: COM14 SAMSUNG Mobile USB Serial Port Software version: 24.2 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.2 |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
02-13-2016, 02:25 | #15600 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-T399N Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: SGH-T399N Android version: 4.4.2 Product code: SGH2T399RNATMB Phone version: T399NUVUANK3 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: RV8G11993LJ Modem board: SS222 RF cal date: 20150127 IMEI: 358765060187370 Checking Super user right... true Reading nv data... OK Detected new type of security Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
