07-05-2016, 01:14 | #16426 (permalink) |
Insane Poster Join Date: Aug 2014
Member: 2235272 Status: Offline Thanks Meter: 4 | Galaxy S7 G935f - FRP Done Code: Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash Interface... detected COM10 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1APB3 CSC version: G935FIUS1APB2 CSC country code: Mexico CSC sales code: IUS HW version: Phone S/N: RF8H408VH8T Modem board: RF cal date: IMEI: Checking Super user right... true Erasing FRP... OK Restore original kernel? Yes Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done |
The Following User Says Thank You to merenguito For This Useful Post: |
07-05-2016, 08:27 | #16427 (permalink) |
Freak Poster Join Date: Jun 2012 Location: India Pune
Member: 1778852 Status: Offline Sonork: 100.1641316 Thanks Meter: 231 | SM-J110H Hang On Logo Problem Solved By Z3x FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J110H Software version: 25.8 File analysis... OK Total file size: 0x3B5CA9C0 (949 Mb) Searching USB Flash Interface... detected COM8 Setup connection... OK Reading PIT from phone... OK Sending spl.img... OK Sending sboot.bin... OK Sending sboot2.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending SPRDCP.img... OK Sending SPRDDSP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:01:53) Done with Samsung Tool PRO v.25.8 |
The Following User Says Thank You to Gsm Narendra For This Useful Post: |
07-05-2016, 14:15 | #16429 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | SM-J110H Country unlock code calculation Operation: Read Codes Selected model: SM-J110H/DS Software version: 25.9 Searching Samsung modem... detected COM60 Reading phone info... OK Model: SM-J110H Version: J110HXXU0APB2/J110HOJV0APB2/J110HXXU0APB2/J110HXXU0APB2 Product code: SM-J110HZWDKSA Phone S/N: RV1H31K4ZDT Imei: 358817070182493 Unique number: CNJ00B8F9CCFF33 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:59) Freeze code: 48180605 NET lock: 35317464 For check lock status: *#7465625# Done with Samsung Tool PRO v.25.9 Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
07-05-2016, 17:15 | #16430 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G530h Cert Write Code: Operation: Write CERT Selected model: SM-G530H Selected port: COM1 Communications Port Software version: 25.9 Checking certificate file... OK KEY ID: 0504 Waiting ADB device... OK Reading phone info... Model: SM-G530H Android version: 4.4.4 Product code: SM-G530HZWDKSA Phone version: G530HXXU1ANIJ PDA version: G530HXXU1ANIJ CSC version: G530HOJV1ANJ1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone S/N: Modem board: MSM8216 RF cal date: 2014.12.24 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0504 Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.25.9 |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
07-05-2016, 19:39 | #16431 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G925T Software version: 25.9 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G925T Android version: 5.1.1 Product code: Phone version: G925TUVU3DOI1 PDA version: G925TUVU3DOI1 CSC version: G925TTMB3DOI1 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: R1234567890 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 08 EB 91 0E B6 05 00 00 00 00 00 00 00 00 00 00 Reading nv data... OK Checking NV data... OK Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.9 |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
07-07-2016, 00:29 | #16432 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Unlock done M919V by 25.9 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-M919V Selected port: COM123 SAMSUNG Mobile USB Serial Port Software version: 25.9 Reading phone info... Reading IMEI... OK IMEI: 355987050591493 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.9 |
07-07-2016, 08:55 | #16433 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | G920F Android 6.0.1 Write CERT DONE Code: Operation: Write CERT Selected model: SM-G920F Software version: 25.9 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: SM-G920FZDASER Phone version: G920FXXU3DPB6 PDA version: G920FXXU3DPBG CSC version: G920FOXE3DPAD CSC country code: Russia CSC sales code: SER HW version: MP 0.900 Phone S/N: RF8XXXXXXX Modem board: SHANNON333 RF cal date: 20150731 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 08 77 CE AD D6 05 00 00 00 00 00 00 00 00 00 00 Checking certificate file... OK KEY ID: 0346 Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.25.9 |
07-07-2016, 19:02 | #16435 (permalink) |
Freak Poster Join Date: Mar 2015 Age: 48
Member: 2371123 Status: Offline Thanks Meter: 4 | SAMSUNG G920I IMEI : 350000000000... Waiting ADB device... OK Reading phone info... Model: SM-G920I Android version: 5.1.1 Product code: Phone version: G920IDVU2COGA PDA version: G920IDVU2COGA CSC version: G920IUUB2COGA CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 08 43 44 B7 74 04 00 00 00 00 00 00 00 00 00 00 Reading nv data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.25.9 Please help me thank advanced. |
07-08-2016, 09:40 | #16437 (permalink) |
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | Operation: Unlock Selected model: GT-I8190 Software version: 25.9 Waiting ADB device... OK Reading phone info... Model: GT-I8190 Android version: 4.1.1 Product code: GT-I8190RWAATO Phone version: I8190XXALJL PDA version: I8190XXALJL CSC version: I8190OXXALJ8 CSC country code: Austria CSC sales code: ATO HW version: MP 0.700 Phone S/N: R21XXXXXXX Modem board: DB8520H RF cal date: 2013.07.28 IMEI: 3583XXXXXXXXXX Checking Super user right... true Reading data from phone... OK Analysing SEC file... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.9 |
07-08-2016, 10:48 | #16438 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Bangladesh Age: 40
Member: 1703431 Status: Offline Sonork: 100.1619192 QQ 3271159180 Thanks Meter: 2,106 | Samsung SM-J500H Custom Binary Block By FRP Problem Solved Done By Z3X Samsung SM-J500H Custom Binary Block By FRP Problem Solved Done By Z3X |
07-08-2016, 19:22 | #16439 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Macedonia Age: 53
Member: 79576 Status: Offline Thanks Meter: 18 | G925S Successfully reset pattern lock Operation: Reset Pattern Lock Selected model: SM-G925S Software version: 25.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM25 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G925SKSU3DPD3 Platform: exynos7420 Boot serial: 05157df5a1e49933 Product board: zerolte Erasing locks... OK Rebooting phone... OK Reset locks done Done with Samsung Tool PRO v.25.9 |
07-08-2016, 22:27 | #16440 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | downgraded and unlock n910t3 from 6.0.1 to 5.1.1 and unlock no root without no problem to all user ,the z3x team they try they bast and they just charging you for activation just $70 and all of you know that you could make that money from one *******r so the z3x team help you and give you solution after that if you have problem you could ask the team kindly so do not be upset and wait until they help you and use your barn thx z3x |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
