11-08-2016, 14:16 | #17116 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Selected model: GT-I5500 Selected port: COM3 Z3X BOX Serial Port, Software version: 20.0 Checking phone at COM3 Reading phone info... OK Model: GT-I5500 Country code: ½ºÀ§½º Cal date: 2011-06-22 Factory SW: I5500XWJPT_OXXJP8 Unique number: 21190000004939 Memory phone: K5W4G2GACB(I5500) Phone S/N: RDDB839958 PDA/CSC version: I5500XWJPT/I5500OXXJP8 Phone version: I5500XWJP4 Phone HW: MP 0.700 Cal date: 2011.08.06 Reading IMEI... OK IMEI: 354796041849022 Bypass MSL... OK Reading codes... OK Freeze code: 17042419 NET lock: 40250852 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.20.0 |
11-08-2016, 15:50 | #17117 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Samsung J120F Unlock Done Operation: Reset Pattern Lock Selected model: SM-J120F Software version: 27.1 Checking local file... ok Searching server... ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... ok Reading data from phone... ok Sending data to phone... ok Sending data to phone... ok Waiting ADB device... ok Reading phone info... Recovery build version: 5.1.1 Boot version: J120FXXU1AOL3 Platform: exynos3475 Boot serial: 42009f7f970123fb Product board: j1xlte Erasing locks... ok Rebooting phone... ok Reset locks done Done with Samsung Tool PRO v.27.1 |
The Following 2 Users Say Thank You to unaiz For This Useful Post: |
11-08-2016, 18:02 | #17118 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Reset FRP Selected model: SM-G550T Software version: 27.1 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... ok Reading phone info... Model: SM-G550T Android version: 6.0.1 Product code: SM2G550TZKATMB Phone version: G550TUVU1APF1 PDA version: G550TUVU1APF1 CSC version: G550TTMB1APF1 CSC country code: USA CSC sales code: TMB HW version: REV0.4 Phone SN: RV8H90MHYEN Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20160920 IMEI: Bypass FRP... ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset Done with Samsung Tool PRO v.27.1 |
The Following 2 Users Say Thank You to ghacks For This Useful Post: |
11-08-2016, 19:34 | #17119 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | SAMSUNG GEAR S UNLOCK DONE UNLOCK INSTRUCTIONS: Device must be rooted! If the software can't root the device automatically, then you must root your device manually. 1. Power on the device. 2. Go to 'Settings' and enable 'USB debugging'. 3. Connect the device to PC, install drivers if needed. 4. Select device in SDB settings. 5. Press 'Unlock' button. Operation: Unlock Selected model: SM-R750T Software version: 27.1 Waiting SDB device... ok Reading phone info... Model: SM-R750T Build: R750TUVU1APC1 Tizen version: Tizen release 2.2.0 (Magnolia) Checking Super user right... true HW version: REV0.3 Phone SN: R5AGB00CKYY Product code: SM-R7500ZWATMB Initialization Tizen RIL... ok Unlocking... ok Rebooting... ok Unlock done Done with Samsung Tool PRO v.27.1 S.G |
11-08-2016, 23:42 | #17120 (permalink) | |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | SGH T399N Imei Repair Quote:
11-09-2016, 01:27 | #17121 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCKED DONE SAMSUNG J120A Operation: Unlock Selected model: SM-J120A Software version: 27.1 Searching Samsung modem... detected COM215 Reading phone info... ok Model: SM-J120A AP version: J120AUCU1APC8 CSC version: J120AATT1APC8 CP version: J120AUCU1APC8 Product code: SM2J120AZWCATT Phone SN: R58H44LQ3HH Unique number: CFN00947E6AAB43 Reading IMEI... ok IMEI: 3562660731XXXX (SIGN: OK) Reading data from phone... ok Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.1 S.G |
11-09-2016, 02:05 | #17122 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | FRP DONE SM-G920T Operation: Reset FRP/React/EE Selected model: SM-G920T Software version: 27.1 Searching Samsung USB Flash interface... COM53 detected Setup connection... ok Reading PIT from phone... ok Searching FRP lock... ok Erasing FRP... ok Searching Reactivation lock... ok Erasing Reactivation lock... ok Searching EE lock... ok Erasing EE lock... ok Reset done Done with Samsung Tool PRO v.27.1 S.G |
11-09-2016, 12:49 | #17123 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G361h FRP Reset Code: Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 27.0 Searching Samsung USB Flash interface... COM4 detected Setup connection... ok Reading PIT from phone... ok Searching FRP lock... ok Erasing FRP... ok Searching Reactivation lock... not supported Searching EE lock... ok Erasing EE lock... ok Reset done Done with Samsung Tool PRO v.27.0 |
11-09-2016, 15:27 | #17124 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCK DONE SM-G361H Operation: Unlock Selected model: SM-G361H Software version: 27.1 Searching Samsung modem... detected COM216 Reading phone info... ok Model: SM-G361H Version: G361HXXU0AOJ1/G361HOJV0AOH1/G361HXXU0AOI1/G361HXXU0AOJ1 Product code: SM-G361HHAAXFA Phone SN: R51G91BXH3N IMEI: 35195507281xxxx Unique number: CQN00B42790E082 Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.1 S.G |
11-10-2016, 13:51 | #17127 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung J1 Nxt FRP Reset Done... Operation: Reset FRP Selected model: SM-J105H/DS Software version: 27.0 Waiting ADB device... ok Reading phone info... Model: SM-J105H Android version: 5.1.1 Product code: SM-J105HZWDMWD Phone version: J105HXWU0APA8 PDA version: J105HXWU0APB1 CSC version: J105HOJV0APB1 CSC country code: MOROCCO CSC sales code: MWD HW version: MP 0.2A0 Phone SN: R21H21AAAAA Chip name: SC7727SE Modem board: SC7727SE RF cal date: 20160222 IMEI: Bypass FRP... ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.0 |
11-10-2016, 14:26 | #17128 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | J700H frp android 6.0.1 frp reset done Code: [ 11/10/2016 4:16:00 PM ] Operation: Reset FRP [ 11/10/2016 4:16:00 PM ] Selected model: SM-J700H [ 11/10/2016 4:16:00 PM ] Software version: 27.1 [ 11/10/2016 4:16:00 PM ] [ 11/10/2016 4:16:00 PM ] You must activate ADB before reset FRP Yes [ 11/10/2016 4:16:00 PM ] Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes [ 11/10/2016 4:16:00 PM ] Waiting ADB device... ok [ 11/10/2016 4:16:00 PM ] Reading phone info... [ 11/10/2016 4:16:00 PM ] Model: SM-J700H [ 11/10/2016 4:16:00 PM ] Android version: 6.0.1 [ 11/10/2016 4:16:00 PM ] Product code: SM-J700HZDDEGY [ 11/10/2016 4:16:00 PM ] Phone version: J700HXXU2BPF2 [ 11/10/2016 4:16:00 PM ] PDA version: J700HXXU2BPF9 [ 11/10/2016 4:16:00 PM ] CSC version: J700HOJV2BPF4 [ 11/10/2016 4:16:00 PM ] CSC country code: Egypt [ 11/10/2016 4:16:00 PM ] CSC sales code: EGY [ 11/10/2016 4:16:00 PM ] HW version: MP 0.401 [ 11/10/2016 4:16:00 PM ] Phone SN: R51H222K0SP [ 11/10/2016 4:16:00 PM ] Chip name: EXYNOS7580 [ 11/10/2016 4:16:00 PM ] Modem board: SHANNON310 [ 11/10/2016 4:16:00 PM ] RF cal date: 20160227 [ 11/10/2016 4:16:00 PM ] IMEI: [ 11/10/2016 4:16:00 PM ] Bypass FRP... ok [ 11/10/2016 4:16:00 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' |
11-10-2016, 18:32 | #17129 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | S7562 imei repair done Code: Operation: Repair Selected model: GT-S7562 Software version: 27.1 Reading phone info... Model: GT-S7562 Country code: ھU Cal date: ھU Factory SW: S7562XXALHC Unique number: CJJ03C8C51CE270 Memory phone: ھU Phone SN: R21D7521XV PDA/CSC version: S7562XXALHC/S7562OJVALH3 Phone version: SW VERSION :None Phone HW: MP 0.600 Cal date: 2013.07.13 Reading IMEI... ok IMEI: 355265056501638 Waiting ADB device... ok Reading phone info... Model: GT-S7562 Android version: 4.0.4 Product code: GT2S7562ZKAXSG Phone version: S7562XXLH6 PDA version: S7562XXALHC CSC version: S7562OJVALH3 CSC country code: UAE CSC sales code: XSG HW version: MP 0.600 Phone SN: R21D7521XVB Modem board: RF cal date: 2013.07.13 IMEI: 355265056501638 Checking Super user right... true Reading data from phone... ok Checking files... ok Writing data to phone... ok Rebooting phone... ok Waiting ADB device... ok Reading phone info... Model: GT-S7562 Android version: 4.0.4 Product code: GT2S7562ZKAXSG Phone version: S7562XXLH6 PDA version: S7562XXALHC CSC version: S7562OJVALH3 CSC country code: UAE CSC sales code: XSG HW version: MP 0.600 Phone SN: R21D7521XVB Modem board: RF cal date: 2013.07.13 IMEI: 355265056501638 Checking Super user right... true Repairing IMEI... ok Repairing Slave IMEI... ok Reseting... ok Repair done Done with Samsung Tool PRO v.27.1 |
11-10-2016, 23:05 | #17130 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | SAMSUNG SM-G386T1 UNLOCKED DONE Operation: Unlock Selected model: SM-G386T1 Selected port: COM233 SAMSUNG Mobile USB Serial Port Software version: 27.1 Reading phone info... Reading IMEI... ok IMEI: 35282906464XXXX Unlocking... ok Reseting... ok Unlock done Done with Samsung Tool PRO v.27.1 S.G |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
