01-05-2017, 09:50 | #17476 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Cox`s Bazar, Bangladesh Age: 34
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | Samsung J700H Full Flash Done 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J700H Software version: 27.6 Unpacking file... ok File analysis... Ok Total file size: 0x7F93FB60 (2041 Mb) Searching USB Flash interface... COM31 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending cm.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending modem.bin... Ok Sending cache.img... Ok Sending hidden.img... Ok Flashing done (time - 00:04:11) Done with Samsung Tool PRO v.27.6 |
01-05-2017, 09:51 | #17477 (permalink) |
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | Samsung G530H Unlock Done BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Unlock Selected model: SM-G530H Selected port: COM110 SAMSUNG Mobile USB Serial Port Software version: 27.6 Reading phone info... Reading IMEI... Ok IMEI: 358500060947378 Unlocking... Ok Reseting... Ok Unlock done Done with Samsung Tool PRO v.27.6 |
01-05-2017, 11:49 | #17478 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | SM-G928V write cert done Code: [ 1/4/2017 6:41:00 PM ] Checking CERT file... Ok [ 1/4/2017 6:41:00 PM ] KEY ID: 0472 [ 1/4/2017 6:41:00 PM ] Waiting ADB device... [ 1/4/2017 6:41:00 PM ] Please, allow USB debugging on phone... Ok [ 1/4/2017 6:41:00 PM ] Reading phone info... [ 1/4/2017 6:41:00 PM ] Model: SM-G928V [ 1/4/2017 6:41:00 PM ] Android version: 5.1.1 [ 1/4/2017 6:41:00 PM ] Product code: Not Active [ 1/4/2017 6:41:00 PM ] Phone version: G928VVRU2AOJ2 [ 1/4/2017 6:41:00 PM ] PDA version: G928VVRU2AOJ2 [ 1/4/2017 6:41:00 PM ] CSC version: [ 1/4/2017 6:41:00 PM ] CSC country code: [ 1/4/2017 6:41:00 PM ] CSC sales code: [ 1/4/2017 6:41:00 PM ] HW version: G928V.04 [ 1/4/2017 6:41:00 PM ] Phone SN: R38G900ZV0J [ 1/4/2017 6:41:00 PM ] Modem board: MDM9635M [ 1/4/2017 6:41:00 PM ] RF cal date: 2015.09.02 [ 1/4/2017 6:41:00 PM ] IMEI: [ 1/4/2017 6:41:00 PM ] Incorrect model selected. This may damage your phone. Continue? Yes [ 1/4/2017 6:41:00 PM ] Initialization AT RIL... Ok [ 1/4/2017 6:41:00 PM ] Bypass SPC... Ok [ 1/4/2017 6:41:00 PM ] Checking for compatible phone and cert... Ok [ 1/4/2017 6:42:00 PM ] Phone KEY ID: 0472 [ 1/4/2017 6:42:00 PM ] Writing CERT... Ok [ 1/4/2017 6:42:00 PM ] Checking CERT status... Ok [ 1/4/2017 6:42:00 PM ] Rebooting phone... Ok |
01-05-2017, 13:37 | #17479 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung j3 (j320w8)2016 Unlock done by read code Operation: Read Codes Selected model: SM-J320W8 Software version: 27.7 Searching Samsung modem... detected COM170 Reading phone info... Ok Model: SM-J320W8 AP version: J320W8VLS2APJ1 CSC version: J320W8OYA2APJ1 CP version: J320W8VLS2APJ1 Product code: SM-J320WZAAXAC Phone SN: R28HA2AGGMM Unique number: CQ30048C9F25F83 Reading IMEI... Ok IMEI: 35899807xxxxxxx (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 17 F6 B9 10 B5 C0 D6 94 C6 FF D0 77 A8 1D A0 30 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 51728474 NET lock: 61947370 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 Thanks z3x Team |
The Following User Says Thank You to sr8787 For This Useful Post: |
01-06-2017, 05:01 | #17480 (permalink) |
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung j5 j500fn FRP remove done Operation: Reset FRP/React/EE Selected model: SM-J500FN Selected port: COM3 Z3X BOX Serial Port Software version: 27.7 Searching Samsung USB Flash interface... COM111 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 Thanks z3x Team |
01-06-2017, 05:20 | #17481 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | note 5 SM-N920W8 6.0.1 UNLOCKED DONE UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-N920W8 Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-N920W8 Android version: 6.0.1 Product code: SM-N920WZKABMC Phone version: N920W8VLU4BPK4 PDA version: N920W8VLU4BPK4 CSC version: N920W8OYA4BPK4 CSC country code: Canada CSC sales code: BMC HW version: REV1.0 Phone SN: RF8H417WYZN Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20160412 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON333 Calculating... Ok HWID: 68 8B 85 2F 54 05 00 00 00 00 00 00 00 00 00 00 Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.3 |
01-06-2017, 08:03 | #17482 (permalink) |
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung j5 unlock done Operation: Unlock Selected model: SM-J500FN Selected port: COM75 SAMSUNG Mobile USB Serial Port Software version: 27.4 Reading phone info... Reading IMEI... Ok IMEI: 358321070xxxxxx Unlocking... Ok Reseting... Ok Unlock done Done with Samsung Tool PRO v.27.4 Thanks z3x Team |
01-06-2017, 09:35 | #17483 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-G550T1 Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-G550T1 Android version: 6.0.1 Product code: SM2G550TZKATMK Phone version: G550T1UVU1APF1 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 CSC country code: USA CSC sales code: TMK HW version: REV0.4 Phone SN: RV8HA0E5ANJ Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20161012 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 74 50 99 23 DD 9F 2B 75 04 18 87 12 EC 04 11 7D Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.7 |
01-06-2017, 14:52 | #17484 (permalink) |
No Life Poster Join Date: May 2007 Location: INDIA
Member: 511749 Status: Offline Thanks Meter: 335 | SAMSUNG G935W8 6.0.1 Unlock By Perfect1 Operation: Read Codes Selected model: SM-G935W8 Software version: 27.7 Searching Samsung modem... detected COM7 Reading phone info... Ok Model: SM-G935W8 AP version: G935W8VLU2APK3 CSC version: G935W8OYA2APK3 CP version: G935W8VLU2APK3 Product code: SM-G935WZSATLS Phone SN: RF8HB0RAPXB Unique number: CE10160AD18ABE0105 Reading IMEI... Ok IMEI: 3561XXXXXXXX739 (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... Ok Reading data from phone... Ok Modem board: SHANNON335 HWID: 9B 67 59 8D BC 5D E9 50 61 0F 54 44 7F 95 87 50 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:07) Freeze code: 50641504 NET lock: 70572808 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Br. Perfect1 Lokesh |
01-07-2017, 08:54 | #17486 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Searching Samsung modem... detected COM402 Reading phone info... Ok Model: SM-G930F AP version: G930FXXU1BPLB CSC version: G930FOXA1BPLB CP version: G930FXXU1BPJJ Product code: SM-G930FZDABTU Phone SN: R58H4192FGD Unique number: 9886784E4E464D3341 Reading IMEI... Ok IMEI: 359467072387093 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON335 HWID: 88 72 97 FE 3A E3 82 BC 56 6C 61 AC C1 36 DF 89 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 02474196 NET lock: 50282036 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
01-07-2017, 10:21 | #17487 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | J120f Unlock Done Searching Samsung modem... detected COM94 Reading phone info... Ok Model: SM-J120F AP version: J120FXXU1APJ1 CSC version: J120FOJV1APJ5 CP version: J120FXXU1APJ2 Product code: SM-J120FZWDKSA Phone SN: R58HB179Y0M Unique number: CFN004151DB00A3 Reading IMEI... Ok IMEI: 352719088275861 (SIGN: OK) IMEI 2: 352720088275869 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: C4 5D 3F 9D 3B A6 27 F9 7B 56 65 B0 27 C5 0C FA Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:03) Freeze code: 20247150 NET lock: 71717502 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
01-07-2017, 13:59 | #17488 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | n920t 6.0.1 Operation: Unlock Selected model: SM-N920T Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-N920T Android version: 6.0.1 Product code: SM2N920TZKATMB Phone version: N920TUVU4DPK6 PDA version: N920TUVU4DPK6 CSC version: N920TTMB4DPK6 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: RF8H30P3RHE Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20160307 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON333 HWID: 68 72 2D 4C 36 04 00 00 00 00 00 00 00 00 00 00 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done love my BOX Done with Samsung Tool PRO v.27.7 |
01-07-2017, 15:39 | #17490 (permalink) |
Freak Poster Join Date: May 2011 Location: B A N G L A D E S H Age: 40
Member: 1578627 Status: Offline Sonork: 100.1623412 Thanks Meter: 501 | Samsung SM-G532F Successfully Unlock By Z3X Box Samsung SM-G532F Successfully Unlock By Z3X Box shohag_bd |
The Following 2 Users Say Thank You to Shohag_bd For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
