04-15-2017, 14:09 | #18137 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | sgh-m620 hang on logo done by flashing Code: Selected model: M620 Selected com port: COM392 Selected speed port: 921600 Decode *.s3 file - please wait segments 9 segment 1 20078000 1096884 byte segment 2 2000C000 20756 byte segment 3 20058000 56 byte segment 4 20058138 17710 byte segment 5 2003803C 36696 byte segment 6 20000000 100 byte segment 7 20300000 29070116 byte segment 8 2001E000 160 byte segment 9 20016000 5056 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 0100003D7E22 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 9 Format FFS - wait... OK Send content - wait... OK Elapsed time: 991 second, sw ver: 3.5.0040 |
The Following User Says Thank You to helpo For This Useful Post: |
04-15-2017, 15:36 | #18139 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | SM A500F CERT WRITE DONE Operation: Write CERT Selected model: SM-A500F Selected port: COM124 SAMSUNG Mobile USB Serial Port Software version: 28.1 Checking CERT file... Ok KEY ID: 0756 Waiting ADB device... Ok Reading phone info... Model: SM-A500F Android version: 5.0.2 Product code: SM-A500FZWAXSG Phone version: A500FXXU1BOJ5 PDA version: A500FXXU1BOK1 CSC version: A500FOJV1BOK1 CSC country code: UAE CSC sales code: XSG HW version: MP 1.100 Phone SN: RF8G21F120F Modem board: MSM8916 RF cal date: 2015.02.25 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0756 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.28.1 |
The Following User Says Thank You to bright hlatini For This Useful Post: |
04-16-2017, 08:14 | #18140 (permalink) |
Freak Poster Join Date: Apr 2016
Member: 2560499 Status: Offline Thanks Meter: 97 | SM-J710GN Unlock Done Searching Samsung modem... detected COM97 Reading phone info... Ok Model: SM-J710GN AP version: J710GNDXU2APL1 CSC version: J710GNOLB2APL1 CP version: J710GNDXU2APL1 Product code: SM-J710GZDUXME Phone SN: RF8J12EDTZE Unique number: C000075291473B3 Reading IMEI... Ok IMEI: 358447077560101 (SIGN: OK) IMEI 2: 358448077560109 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done |
04-16-2017, 08:40 | #18141 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2702031 Status: Offline Thanks Meter: 0 | Selected model: C160B Selected com port: COM10 Selected speed port: 460800 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Timeout Unlock - fail Elapsed time: 23 second, sw ver: 3.4.0065 ------------------------------------------------------------------------------- Selected model: C160 Selected com port: COM10 Selected speed port: 460800 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK Flash ID: A00300C2EC52 Sending loader2... OK Unlock block Unlock block If lock - not deactivate: try with code 00000000 Unlock - ok Elapsed time: 64 second, sw ver: 3.4.0065 |
04-16-2017, 08:59 | #18142 (permalink) |
Insane Poster Join Date: Dec 2013 Location: saudi arabiya Age: 31
Member: 2085357 Status: Offline Sonork: 100.1587837 Thanks Meter: 17 | galaxy not5 android 7.0 FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Reset FRP/React/EE Selected model: SM-N920C Software version: 28.1 Searching Samsung USB Flash interface... COM34 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 |
04-16-2017, 09:14 | #18143 (permalink) |
Freak Poster Join Date: May 2014 Location: MUMBAI INDIA
Member: 2194159 Status: Offline Thanks Meter: 88 | Samsung s7 edge sm-g935f android 7.0 1 click unlock done with z3x pro SAMSUNG S7 EDGE SM-G935F ANDROID 7.0 1 CLICK UNLOCK DONE WITH Z3X PRO REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Unlock Selected model: SM-G935F Software version: 28.0 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 7.0 Product code: SM-G935FZBUKSA Phone version: G935FXXU1DQB3 PDA version: G935FXXU1DQBO CSC version: G935FOJV1DQB7 CSC country code: KSA CSC sales code: KSA HW version: MP 0.801 Phone SN: RF8J30K974Y Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-02-01 RF cal date: 20170306 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: AD A9 DD CF 8B 67 82 58 BB 0D 33 6F FD AA F8 46 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.0 [IMG]RL=http://s1303.photobucket.com/user/mdrashid78692/media/S7%20EDGE%20SM-G935F%20ANDROID%207.0%20COUNTRY%20UNLOCK%20DONE%20 WITH%20Z3X%201_zps00az8g4f.png.html][/URL][/IMG] |
04-16-2017, 09:46 | #18144 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,751 | J100H\DS imei repair done Code: [ 4/14/2017 5:37:00 PM ] Operation: Repair [ 4/14/2017 5:37:00 PM ] Selected model: SM-J100H/DS [ 4/14/2017 5:37:00 PM ] Software version: 28.1 [ 4/14/2017 5:37:00 PM ] [ 4/14/2017 5:37:00 PM ] [ 4/14/2017 5:37:00 PM ] Waiting ADB device... Ok [ 4/14/2017 5:37:00 PM ] Reading phone info... [ 4/14/2017 5:37:00 PM ] Model: SM-J100H [ 4/14/2017 5:37:00 PM ] Android version: 4.4.4 [ 4/14/2017 5:37:00 PM ] Product code: SM-J100HZWDMID [ 4/14/2017 5:37:00 PM ] Phone version: J100HXXU0APD1 [ 4/14/2017 5:37:00 PM ] PDA version: J100HXXU0APD1 [ 4/14/2017 5:37:00 PM ] CSC version: J100HOJV0APE1 [ 4/14/2017 5:37:00 PM ] CSC country code: Iraq [ 4/14/2017 5:37:00 PM ] CSC sales code: MID [ 4/14/2017 5:37:00 PM ] HW version: MP 0.201 [ 4/14/2017 5:37:00 PM ] Phone SN: RV1G61FRRBX [ 4/14/2017 5:37:00 PM ] Modem board: sc7727s [ 4/14/2017 5:37:00 PM ] RF cal date: 20150616 [ 4/14/2017 5:37:00 PM ] IMEI: [ 4/14/2017 5:37:00 PM ] Checking Super user right... true [ 4/14/2017 5:37:00 PM ] Checking MSL... Ok [ 4/14/2017 5:37:00 PM ] Initialization AT RIL... Ok [ 4/14/2017 5:37:00 PM ] Bypass MSL Ok [ 4/14/2017 5:38:00 PM ] Repairing IMEI... Ok [ 4/14/2017 5:38:00 PM ] Repairing Slave IMEI... Ok [ 4/14/2017 5:38:00 PM ] Rebooting phone... Ok [ 4/14/2017 5:38:00 PM ] Repair done [ 4/14/2017 5:38:00 PM ] [ 4/14/2017 5:40:00 PM ] Operation: Patch Certificate [ 4/14/2017 5:40:00 PM ] Selected model: SM-J100H/DS [ 4/14/2017 5:40:00 PM ] Software version: 28.1 [ 4/14/2017 5:40:00 PM ] [ 4/14/2017 5:40:00 PM ] Waiting ADB device... Ok [ 4/14/2017 5:40:00 PM ] Reading phone info... [ 4/14/2017 5:40:00 PM ] Model: SM-J100H [ 4/14/2017 5:40:00 PM ] Android version: 4.4.4 [ 4/14/2017 5:40:00 PM ] Product code: SM-J100HZWDMID [ 4/14/2017 5:40:00 PM ] Phone version: J100HXXU0APD1 [ 4/14/2017 5:40:00 PM ] PDA version: J100HXXU0APD1 [ 4/14/2017 5:40:00 PM ] CSC version: J100HOJV0APE1 [ 4/14/2017 5:40:00 PM ] CSC country code: Iraq [ 4/14/2017 5:40:00 PM ] CSC sales code: MID [ 4/14/2017 5:40:00 PM ] HW version: MP 0.201 [ 4/14/2017 5:40:00 PM ] Phone SN: RV1G61FRRBX [ 4/14/2017 5:40:00 PM ] Modem board: sc7727s [ 4/14/2017 5:40:00 PM ] RF cal date: 20150616 [ 4/14/2017 5:40:00 PM ] IMEI: [ 4/14/2017 5:40:00 PM ] Checking Super user right... true [ 4/14/2017 5:40:00 PM ] Patching CERT check... Ok [ 4/14/2017 5:40:00 PM ] Rebooting phone... Ok [ 4/14/2017 5:40:00 PM ] Patching CERT check... done |
04-16-2017, 09:47 | #18145 (permalink) |
Member: 2085357 Status: Offline Sonork: 100.1587837 Thanks Meter: 17 | android 7 not5 Operation: Flash Selected model: SM-N920C Software version: 28.1 File analysis... Ok Total file size: 0xE412B6F0 (3649 Mb) Searching USB Flash interface... COM34 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending cm.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending cache.img... Ok Sending hidden.img... Ok Sending modem.bin... Ok Flashing done (time - 00:02:58) Done with Samsung Tool PRO v.28.1 |
04-16-2017, 09:51 | #18146 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,751 | N7100 Imei repair done Code: [ 4/14/2017 7:20:00 PM ] Operation: Repair [ 4/14/2017 7:20:00 PM ] Selected model: GT-N7100 [ 4/14/2017 7:20:00 PM ] Software version: 28.1 [ 4/14/2017 7:20:00 PM ] [ 4/14/2017 7:20:00 PM ] [ 4/14/2017 7:20:00 PM ] Waiting ADB device... Ok [ 4/14/2017 7:20:00 PM ] Reading phone info... [ 4/14/2017 7:20:00 PM ] Model: GT-N7100 [ 4/14/2017 7:20:00 PM ] Android version: 4.3 [ 4/14/2017 7:20:00 PM ] Product code: Not Active [ 4/14/2017 7:20:00 PM ] Phone version: N7100DDEMJ9 [ 4/14/2017 7:20:00 PM ] PDA version: N7100XXUEMK9 [ 4/14/2017 7:20:00 PM ] CSC version: N7100EPLEMK1 [ 4/14/2017 7:20:00 PM ] CSC country code: Germany [ 4/14/2017 7:20:00 PM ] CSC sales code: EPL [ 4/14/2017 7:20:00 PM ] HW version: Unknown [ 4/14/2017 7:20:00 PM ] Phone SN: 00000000000 [ 4/14/2017 7:20:00 PM ] Modem board: XMM6262 [ 4/14/2017 7:20:00 PM ] RF cal date: Unknown [ 4/14/2017 7:20:00 PM ] IMEI: 004999010640000 [ 4/14/2017 7:20:00 PM ] Checking Super user right... true [ 4/14/2017 7:20:00 PM ] Reading NV data... Ok [ 4/14/2017 7:20:00 PM ] Checking magic... Ok [ 4/14/2017 7:20:00 PM ] Running zTool, please wait... OK [ 4/14/2017 7:21:00 PM ] Detected new type of security version 0 [ 4/14/2017 7:21:00 PM ] Calculating... Ok [ 4/14/2017 7:21:00 PM ] Writing NV Data... Ok [ 4/14/2017 7:21:00 PM ] Rebooting phone... Ok [ 4/14/2017 7:21:00 PM ] Repair done [ 4/14/2017 7:21:00 PM ] |
04-16-2017, 09:52 | #18147 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,751 | S7272 flash done Code: [ 4/16/2017 11:35:00 AM ] Operation: Flash [ 4/16/2017 11:35:00 AM ] Selected model: GT-S7272 [ 4/16/2017 11:35:00 AM ] Software version: 28.1 [ 4/16/2017 11:35:00 AM ] [ 4/16/2017 11:35:00 AM ] File analysis... Ok [ 4/16/2017 11:35:00 AM ] Total file size: 0x57640428 (1398 Mb) [ 4/16/2017 11:35:00 AM ] Searching USB Flash interface... COM19 detected [ 4/16/2017 11:35:00 AM ] Setup connection... Ok [ 4/16/2017 11:35:00 AM ] Reading PIT from phone... Ok [ 4/16/2017 11:35:00 AM ] Sending BcmBoot.img... Ok [ 4/16/2017 11:35:00 AM ] Sending sboot.bin... Ok [ 4/16/2017 11:35:00 AM ] Sending param.lfs... Ok [ 4/16/2017 11:35:00 AM ] Sending dt-blob... Ok [ 4/16/2017 11:35:00 AM ] Sending boot.img... Ok [ 4/16/2017 11:35:00 AM ] Sending recovery.img... Ok [ 4/16/2017 11:35:00 AM ] Sending system.img... Ok [ 4/16/2017 11:41:00 AM ] Sending userdata.img... Ok [ 4/16/2017 11:42:00 AM ] Sending BcmCP.img... Ok [ 4/16/2017 11:42:00 AM ] Sending cache.img... Ok [ 4/16/2017 11:42:00 AM ] Sending hidden.img... Ok [ 4/16/2017 11:42:00 AM ] Flashing done (time - 00:07:29) [ 4/16/2017 11:42:00 AM ] |
04-16-2017, 09:54 | #18148 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,751 | SM-B310E flash successfully Code: [ 4/15/2017 4:56:00 PM ] Operation: Flash [ 4/15/2017 4:56:00 PM ] Selected model: SM-B310E [ 4/15/2017 4:56:00 PM ] Software version: 28.1 [ 4/15/2017 4:56:00 PM ] [ 4/15/2017 4:56:00 PM ] Waiting phone... detected COM25 [ 4/15/2017 4:56:00 PM ] Sending FDL... Ok [ 4/15/2017 4:56:00 PM ] Reconnecting phone... Ok [ 4/15/2017 4:56:00 PM ] Reading NV... Ok [ 4/15/2017 4:56:00 PM ] Saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\NV\nvitem_SM-B310E_15-4-2017_16-56-37.bin [ 4/15/2017 4:56:00 PM ] Sending SSBOOT... Ok [ 4/15/2017 4:56:00 PM ] Sending PS... Ok [ 4/15/2017 4:57:00 PM ] Sending CSC... Ok [ 4/15/2017 4:58:00 PM ] Erasing FLASH... Ok [ 4/15/2017 4:58:00 PM ] Flashing done (time - 00:01:41) [ 4/15/2017 4:58:00 PM ] |
04-16-2017, 09:56 | #18149 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,751 | SM-G355H\DS imei repair done Code: [ 4/14/2017 11:20:00 AM ] Operation: Repair [ 4/14/2017 11:20:00 AM ] Selected model: SM-G355H/DS [ 4/14/2017 11:20:00 AM ] Software version: 28.1 [ 4/14/2017 11:20:00 AM ] [ 4/14/2017 11:20:00 AM ] [ 4/14/2017 11:20:00 AM ] Waiting ADB device... Ok [ 4/14/2017 11:20:00 AM ] Reading phone info... [ 4/14/2017 11:20:00 AM ] Model: SM-G355H [ 4/14/2017 11:20:00 AM ] Android version: 4.4.2 [ 4/14/2017 11:20:00 AM ] Product code: SM-G355HZWDPAK [ 4/14/2017 11:20:00 AM ] Phone version: G355HXXU0APF1 [ 4/14/2017 11:20:00 AM ] PDA version: G355HXXU0API1 [ 4/14/2017 11:20:00 AM ] CSC version: G355HOJV0API1 [ 4/14/2017 11:20:00 AM ] CSC country code: PAKISTAN [ 4/14/2017 11:20:00 AM ] CSC sales code: PAK [ 4/14/2017 11:20:00 AM ] HW version: MP 0.500 [ 4/14/2017 11:20:00 AM ] Phone SN: RV1FC0JHL7Z [ 4/14/2017 11:20:00 AM ] Modem board: sc7735s [ 4/14/2017 11:20:00 AM ] RF cal date: 20141208 [ 4/14/2017 11:20:00 AM ] IMEI: [ 4/14/2017 11:20:00 AM ] Checking Super user right... true [ 4/14/2017 11:20:00 AM ] Checking MSL... Ok [ 4/14/2017 11:20:00 AM ] Initialization AT RIL... Ok [ 4/14/2017 11:20:00 AM ] Bypass MSL Ok [ 4/14/2017 11:20:00 AM ] Repairing IMEI... Ok [ 4/14/2017 11:20:00 AM ] Repairing Slave IMEI... Ok [ 4/14/2017 11:20:00 AM ] Rebooting phone... Ok [ 4/14/2017 11:20:00 AM ] Repair done [ 4/14/2017 11:20:00 AM ] [ 4/14/2017 11:23:00 AM ] Operation: Patch Certificate [ 4/14/2017 11:23:00 AM ] Selected model: SM-G355H/DS [ 4/14/2017 11:23:00 AM ] Software version: 28.1 [ 4/14/2017 11:23:00 AM ] [ 4/14/2017 11:23:00 AM ] Waiting ADB device... Ok [ 4/14/2017 11:23:00 AM ] Reading phone info... [ 4/14/2017 11:23:00 AM ] Model: SM-G355H [ 4/14/2017 11:23:00 AM ] Android version: 4.4.2 [ 4/14/2017 11:23:00 AM ] Product code: SM-G355HZWDPAK [ 4/14/2017 11:23:00 AM ] Phone version: G355HXXU0APF1 [ 4/14/2017 11:23:00 AM ] PDA version: G355HXXU0API1 [ 4/14/2017 11:23:00 AM ] CSC version: G355HOJV0API1 [ 4/14/2017 11:23:00 AM ] CSC country code: PAKISTAN [ 4/14/2017 11:23:00 AM ] CSC sales code: PAK [ 4/14/2017 11:23:00 AM ] HW version: MP 0.500 [ 4/14/2017 11:23:00 AM ] Phone SN: RV1FC0JHL7Z [ 4/14/2017 11:23:00 AM ] Modem board: sc7735s [ 4/14/2017 11:23:00 AM ] RF cal date: 20141208 [ 4/14/2017 11:23:00 AM ] IMEI: [ 4/14/2017 11:23:00 AM ] Checking Super user right... true [ 4/14/2017 11:23:00 AM ] Patching CERT check... Ok [ 4/14/2017 11:23:00 AM ] Rebooting phone... Ok [ 4/14/2017 11:23:00 AM ] Patching CERT check... done [ 4/14/2017 11:23:00 AM ] |
04-16-2017, 09:57 | #18150 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,751 | J500H updated to MM(6.0.1)successfully Code: [ 4/15/2017 6:24:00 PM ] Operation: Flash [ 4/15/2017 6:24:00 PM ] Selected model: SM-J500H [ 4/15/2017 6:24:00 PM ] Software version: 28.1 [ 4/15/2017 6:24:00 PM ] [ 4/15/2017 6:24:00 PM ] File analysis... Ok [ 4/15/2017 6:24:00 PM ] Total file size: 0xC3E0CAF0 (3134 Mb) [ 4/15/2017 6:24:00 PM ] Searching USB Flash interface... COM10 detected [ 4/15/2017 6:24:00 PM ] Setup connection... Ok [ 4/15/2017 6:24:00 PM ] Set PIT file... Ok [ 4/15/2017 6:24:00 PM ] Reading PIT from phone... Ok [ 4/15/2017 6:24:00 PM ] Sending aboot.mbn... Ok [ 4/15/2017 6:24:00 PM ] Sending sbl1.mbn... Ok [ 4/15/2017 6:24:00 PM ] Sending rpm.mbn... Ok [ 4/15/2017 6:24:00 PM ] Sending tz.mbn... Ok [ 4/15/2017 6:24:00 PM ] Sending hyp.mbn... Ok [ 4/15/2017 6:24:00 PM ] Sending NON-HLOS.bin... Ok [ 4/15/2017 6:24:00 PM ] Sending sec.dat... Ok [ 4/15/2017 6:24:00 PM ] Sending boot.img... Ok [ 4/15/2017 6:24:00 PM ] Sending recovery.img... Ok [ 4/15/2017 6:24:00 PM ] Sending system.img.ext4... Ok [ 4/15/2017 6:28:00 PM ] Sending persist.img.ext4... Ok [ 4/15/2017 6:28:00 PM ] Sending userdata.img.ext4... Ok [ 4/15/2017 6:30:00 PM ] Sending modem.bin... Ok [ 4/15/2017 6:30:00 PM ] Sending cache.img.ext4... Ok [ 4/15/2017 6:30:00 PM ] Sending hidden.img.ext4... Ok [ 4/15/2017 6:30:00 PM ] Flashing done (time - 00:06:31) [ 4/15/2017 6:30:00 PM ] |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
